Question about ASUS P4P800SE Motherboard
ASUS P4P800 SE power problem
I have a PC with Asus P4P800-SE motherboard and it doesn't turn on when I press the power on button. But the on board power LED lights up when I connect the power supply to AC supply. I have tested it with brand new power supply and still doesn't work. I have also checked the power button for continuity, it works fine. I tried short circuiting the power switch connectors with a screw driver. Still doesn't power up. Can anyone give suggestions on how to fix it?
I wan't sound driver of asus P4P800-SE PLEASE,,, GIVE THE DRIVER, I VERY NEED IT!!
It's always best to download from the maker's (ASUS) website to ensure you have the latest version.
Jun 02, 2011 | ASUS P4P800 SE (890552603657) Motherboard
Download ethernet controller drivers for p4p800 se asus mainboard
Go to the follwong site and follow these steps: -
http://support.asus.com/download/download.aspx?SLanguage=en-us
1. Select Product - Mother board
2. Select Series - Socket478
3. Select Model -
P4P800 SE and click search, it would ask you for operating system
4. Select operating system and download drivers
Hope it helps!
CreativeTECH
Nov 22, 2010 | ASUS P4P800 SE (890552603657) Motherboard
I have a asus p4p800 se mobo everything works but when i push the power button i get no video. i tried multiple video cards and still nothing
Please Check your motherboard in your motherboard having problem that why its happen please repair motheboard. or Change Motherboard.
May 11, 2010 | ASUS P4P800 SE (890552603657) Motherboard
PCI Simple Communications Controller, seem not to function
Hello my friend
First your motherboard does not support windows 7 and the maximum ram capacity is 4GB DDR400/333/266 non-ECC DDR SDRAM memory
Second you can go here and check which memory your motherboard supports
P4P800 SE Memory QV
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/P4P800_SE_QVL.pdf
Third you can try updating your Bios,more information in your manual
MANUAL
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
your motherboard details is here
http://www.asus.com/product.aspx?P_ID=YNlDkmz5gSNpiCr6&templete=2
Good luck
Jan 14, 2010 | ASUS P4P800 SE (890552603657) Motherboard
The power went out today and my comp. will not turn on the power led is flashing.it is a p4p800se board
Unplug the computer from the wall power socket and, while disconnected, press and hold the power button for a few secs. Reconnect power and test.
Sep 23, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Asus P4P800 SE motherboard
No. Your board can support any AGP video card.
But it does not support any PCI-E cards.
Dec 04, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Try to have the driver of the motherboard p4p800 se sound driver
hello,
You can find your drivers here: http://support.asus.com/download/download.aspx?SLanguage=en-us
Pls input necessary data about your motherboard.
may this help
melnavz
May 02, 2008 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800SE Motherboard Logo
146 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
