Question about Samsung Np350v5c 15.6-Inch Laptop Silver Intel Core I3 2370M 2.4Ghz, 6Gb Ram, 500Gb Hdd, Dvdsm Dl, Lan, Wlan, Webcam, Integrated Graphics, Windows 7 Home Premium 64-Bit
Cmos battery location on samsung np350v
I want to change the battery since the bios time gets wrong all the time.
2 Suggested Answers
  • 98 Answers
SOURCE: BIOS reset
By resetting the CMOS battery all you need to do is to teardown your laptop and have to remove and reinstall the CMOS battery. And for the replacement of the CMOS battery of your Samsung laptop just call SAmsung technical support so that they can give you the exact model of the CMOS battery and where you can have the battery. Thank you.
Posted on Oct 10, 2009
How do i bypass cmos battery
You need to have the battery in order for system to boot, however, you can reset it.
http://www.howtogeek.com/131623/how-to-clear-your-computers-cmos-to-reset-bios-settings/
How to Clear Your Computers CMOS to Reset BIOS Settings
Oct 06, 2016 | Computers & Internet
ASUS Windows 7 laptop cannot keep time! I have checked the bios, and the CMOS battery, and all seems fine. Yesterday it lost 13 MONTHS!! What is wrong?
hi charli, did you change new cmos batter , how you checked your bios cmos battery, if you not changed your cmos battery try to change and check it you may get proper time.
GOOD luck
Dec 31, 2010 | ASUS Computers & Internet
The time on my computer is always wrong. I change it and the minute my screesaver comes on it is wrong again. I think its the cmos battery. I need to know where it is in my laptop....sony pcg-grz660 and...
When you first turn on the machine do you get a message about it reverting to default bios settings? If not I doubt its the CMOS it could be any sort of malware messing with your time settings, especially as you say it happens when the screensaver comes on.
When a CMOS battery starts to go you will notice a change in the bios long before the time goes.
Oct 29, 2010 | Sony VAIO GRZ660 Notebook
Acer aspire IE3450P BIOS Password
A BIOS password is a protection measure that can be used to stop someone powering up a computer system or making changes in some of the computers most sensitive areas. Many big name computer manufacturers such as Dell and HP lock the customers out of this area because they don’t want the customer changing anything and potentially damaging the machine (which the manufacturer may have to warranty). However, when someone like a computer technician or hardware enthusiast needs to make some hardware changes to the computer, they will need to access the BIOS. Here are some methods to bypass or remove a BIOS password.
NOTE: Do not try to guess the password on a pass worded Hard Drive. 3 wrong guesses will often result in the information on the hard drive being lost forever.
How to Bypass or Remove a BIOS Password by Removing the CMOS Battery:
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget a lot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
remove-battery.thumbnail.jpgAnyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
remove-bios-battery.thumbnail.jpg Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during boot up now, you will need to go to “Load BIOS Defaults” in BIOS and save the changes to fix them.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 19, 2010 | Acer Computers & Internet
Time and date stop when laptop powered off.
it sounds like the cmos batt had the same problem with my desk top once changed cmos batt all was fine .the batt is located on the under side of the laptop you will see some removeable panels just check under these,but be carefull the batt might be soldered in, some are some are not. if soldered in you might want to get a professional to change it as the heat could damage your computer.
hope this helps.
Apr 25, 2010 | Computers & Internet
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
CMOS ACER EXTENS E610CDT
Yes, you do have to take it apart. How do you know the cmos battery is bad? Is the time wrong all of the time??Does the BIOS default all the time??
Nov 09, 2007 | Acer Extensa 710TE Notebook
Samsung Np350v5c 15.6-Inch Laptop Silver Intel Core I3 2370M 2.4Ghz, 6Gb Ram, 500Gb Hdd, Dvdsm Dl, Lan, Wlan, Webcam, Integrated Graphics, Windows 7 Home Premium 64-Bit Logo
1,177 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
