Question about Boating
I have 1998 yamaha XL1200 waverunner. It has no power to gages or to even start. I have replaced the battery with a new battery. Is there a fuse or something i can check to regain power to everything?
2 Suggested Answers
  • 3 Answers
SOURCE: i have a 1998 yamaha waverunner XL1200. when i hit
It may be your starter relay if it is clicking from the CPU box
Posted on Jun 28, 2010
Will only get up to 10 mph but RPM's are up to 8000. Impeller in good shape. No exhaust alarms. Newbie to waverunners.
I just had one do basically the same thing. I had to replace the impeller. It felt like a clutch was slipping. If they get any dings or nicks or anything in the impeller they will not getup speed at all.
Aug 17, 2013 | Yamaha 01-05 Xlt 1200 Xl1200 Xl Generator...
Wont start battery fuse good
corrodes wire and connections somewhere ,but where is the million dollar question here ,and without a play i couldnt even hazard a idea
Jul 24, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Just changed the starter motor on my xl1200 limited 1999 and it's now making a grinding noise what should I do ?
U may have the wrong starter or it requires shims ( spacers) to adjust proper clearence.did u possibly drop or not see them when takin out?
Jan 09, 2013 | Yamaha Jet Ski Pwc Cover For Waverunner...
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
1999 Yamaha XL1200 Waverunner starter always turns
i recomend replacing the solinoide !!!
Mar 11, 2012 | Yamaha Boating
I have a yamaha waverunner 700y. The battery is charfged but it wont start. It makes a clunk sound when I poush the start button. The in line fuse looks good. Any other suggestions? JT
Tap on the starter with a plastic hammer. If it works you need new brushes. If it does not turn the motor over, remove the starter , open it and see if water has gotten inside. If so you will have to replace it.
Aug 06, 2010 | Yamaha G5 Motorcycles
I have a 1998 yamaha waverunner XL1200. when i hit the start button it sounds like power going to the starter but won't start. only after the 3rd try. dose it need to be changed.
Corrosion in the leads can do this.Even if the leads look good,they may not be.Every lead needs to be taken off,cleaned,put a protectant on it,and put back together.the main power lead can look 100% but it may not be.My ski had the same issue and a small shake on the main lead showed me it needed fixing.This work costs nothing, but can fix a problem that a shop will charge heaps.Hope this helps
Jun 22, 2010 | Boating
I have a 2000 Yamaha XL1200 waverunner. When I went to start it, the existing battery was weak. So, I put in a new battery and now it won't even try to start.
my 1998 xl 1200 has this thing it the batter is changed or if it sits for awhile you have to hit mode then something that says code should pop up on the screen then hit a b c a and then it should be able to start. but your code may be different
Jun 20, 2010 | Yamaha 12V Air Pump
How do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
Jun 28, 2009 | Yamaha 12V Air Pump
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
