Question about Electrolux EW1000i Front Load Washer
Electrolux ewx14440w washer dryer will not heat water
  • Official Brand Answer
  • 4,342 Answers
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Posted on Nov 01, 2012
2 Suggested Answers
  • 174 Answers
SOURCE: electrolux ewx14440w starts but then turns off no
check the motor or heater is not down to earth. you need 500v insulation tester for this.
Posted on Jul 20, 2010
Electrolux Insight Iron Aid. Why does it steam up kitchen?
Electrolux Wave Touch Dryer Problems. It Leaks! - YouTube
? 2:12
https://www.youtube.com/watch?v=uMFpFVOFE5M
Sep 27, 2012 - Uploaded by erik malewski
My less than a week old Electrolux Wave Touch Dryer leakedfrom the perfect steam inlet all over my ...
Water under my Steam Dryer (May: condo, appliances, house ...
www.city-data.com > City-Data Forum > US Forums > Oklahoma
Aug 15, 2012 - My washer and dryer is an Electrolux designed in Italy to Sears ... wasleaking; but the repairman said it wasn't and that the dryer just had built ...
Electrolux steam dryer Questions & Answers - Fixya
Jan 01, 2016 | Dryers
I have an Electrolux Washer Dryer EWX14440W - the missus loves it but today it stopped working completely (no power). I have checked there is power getting to the machine's cable and the fuse on the
inside the machine youll find a 10 amp fuse
DONT just replace it
find out why it died perhaps a bad pump
however if it has earth leakage then you would find your mains box trips would break
depends on your house lecky if you have fuses or breakers
to kill the mains 10 amp is bad
so if its a mains fail then
think that if you have mains throw thru current leakage
then it must be a short in the mains
too blow the fuses this takes more than 10 amps
and not water stuff to earth
i think some machines have resetable fuses
inside a flap on the back
i also think your machine is full of oose and blockage
three faults at once crap crub and crust in pumps and air flows heaters etc have caused it too over heat
you may also need to reset the popup fuses on the tumble heater section
Oct 01, 2014 | Washing Machines
Zwd14581w - both washer/tumble not getting warm
Possibly the heating element is enclosed by chalc buildup. The heat is still built up, but isolated from the washing water by chalc. Loopup methods to clean the washer or ask a professional.
Dec 17, 2013 | Electrolux Zwd14581w Zanussi Washer/Dryer...
Hello I have a washing machine EWX14440W and the green Start Pause LED light is flashing. I have cleaned the fluff filter, turned off the mains and turned it back on again, done a short dry cycle...
http://data.manualslib.com/pdf/5/461/46091-electrolux/ewx_14440_w.pdf?dabc55afaee556910dced33ebba5ef18
This is the manual on your machine. Unfortunately there is no info on the blinking light so I am assuming that it is a delayed start. Now remember this is a high efficiency machine so it may not seem like it is doing anything when it is. As far as the drying part is concerned, check your drying temp. selection.
Dec 10, 2013 | Electrolux Washing Machines
Electrolux washer dryer EWX14440W. It just seems to have died. No power, noise, lights, error codes or other signs of life. Can anyone advise where to start?
check fuse in plug ,check main circuit breaker tripped also do u have a neon switch on wall in room check this fuse also, to check scoket out let plug some thing else thats works to check out scoket out let
Aug 31, 2013 | Electrolux Washing Machines
HOW DO I CHANGE HEATING ELEMENT ON MY ELECTROLUX DRYER?
You might try this step by step process. It is not for Electrolux, but the process should be similar. Changing the Heating Element
Apr 08, 2013 | Electrolux EIED55HMB Electric Front Load...
Electrolux ewx14440w starts but then turns off no codes show last time it was the heating element
Jul 20, 2010 | Electrolux Washing Machines
I have an electrolux EWX14440W Washing machine,
could be your door interlock is faulty
Mar 01, 2010 | Washing Machines
Electrolux EW1000i Front Load Washer Logo
356 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
