Question about Hardware & Accessories
We have Noma thermostat and are having problems programming it
What does the P1 P2 and P3 mean?
  • 5,245 Answers
Usually it means:
Program 1, with ON or OFF displaying somewhere on screen
Program 2
Program 3
Each program needs ON time, and OFF time, and day(s)-of-operation selection.
Copy following link for possible manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#TM-023
Posted on Oct 29, 2012
What does a P3 code mean? On a Hobart LXI high temp
P3 code refers to the probe near the airgap at the back. It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you can access the memory and clear it.
Jan 05, 2014 | Dishwashers
Having problems programming thermostat. It is a digital 7 day timer
Programmable thermostats and timers require program to be entered using keypad
Program 2
Program 3
Oct 28, 2012 | Hardware & Accessories
Why is p1 flashing on my t500 treadmill
Please see your owner manual , page 18-19 you will see the Workout p1+p2+p3 etc Code for your treadmill Horizon.
If you do not have the owner manual please download:
www.horizonfitness.com, go to service customer then parts&manuals give you model, etc, and download for free.
sincerely.
Mery Christmas.
ernesto cuadra
managua, nicaragua. c.a
Dec 11, 2011 | Exercise & Fitness
KENWOOD DNX5120 DVD Navigation System GPS Receiver: I just purchased a used vehicle with this system. ...
Its a lil Play button at da bottom of screen wen on tuner! tap it until it say p1 p2 p3 etc, turn to wat station you want and hold either p1 p2 p3 etc!
May 09, 2010 | Kenwood DNX5120 DVD Navigation System GPS...
We have a p1 code?
p1 is in the testing mode the hour button will click p1 p2 and p3 depending on how many times you click the hour button or minute button . This is to manually test the burner on low , medium, or high p1 being low.To put it in this mode hold the minute and hr buttons down at the same time for 3 seconds.I unplugged the unit to reset.
Dec 20, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Send to read/writer a plus hoop design it only reads the p1 file
After I stitch out the p1, I have to go back and load the p2 design and continue stitching after I adjust the hoop to the p2 setting. Then I do the same thing with the p3. It is a pain to go back and forth, but it works!
Nov 08, 2009 | Husqvarna Rose
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
How to create owr own calculater
for all os ? you must use java language! this is the code:
//<applet code="calmayank"height=300 width=300></applet>
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class calmayank extends JApplet
implements ActionListener
JTextField t1;
JButton b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,
b11,b12,b13,b14,b15,b16,b17,b18,b19,b20;
GridLayout gl;
JPanel p1,p2,p3;
public void init()
gl=new GridLayout(5,4);
p1=new JPanel();
p2=new JPanel();
p3=new JPanel();
p1.setLayout(gl);
t1=new JTextField(17);
b1=new JButton("1");
b2=new JButton("2");
b3=new JButton("3");
b4=new JButton("4");
b5=new JButton("5");
b6=new JButton("6");
b7=new JButton("7");
b8=new JButton("8");
b9=new JButton("9");
b10=new JButton("0");
b11=new JButton("+");
b12=new JButton("-");
b13=new JButton("*");
b14=new JButton("/");
b15=new JButton("@");
b16=new JButton("$");
b17=new JButton("%");
b18=new JButton(".");
b19=new JButton("?");
b20=new JButton("=");
p2.add(t1);
p1.add(b1);
p1.add(b2);
p1.add(b3);
p1.add(b4);
p1.add(b5);
p1.add(b6);
p1.add(b7);
p1.add(b8);
p1.add(b9);
p1.add(b10);
p1.add(b11);
p1.add(b12);
p1.add(b13);
p1.add(b14);
p1.add(b15);
p1.add(b16);
p1.add(b17);
p1.add(b18);
p1.add(b19);
p1.add(b20);
p3.add(p2);
p3.add(p1);
getContentPane().add(p3);
b1.addActionListener(this);
b2.addActionListener(this);
b3.addActionListener(this);
b4.addActionListener(this);
b5.addActionListener(this);
b6.addActionListener(this);
b7.addActionListener(this);
b8.addActionListener(this);
b9.addActionListener(this);
public void actionPerformed(ActionEvent e)
if(e.getSource()==b1)
t1.setText("1");
else if(e.getSource()==b2)
t1.setText("2");
else if(e.getSource()==b3)
t1.setText("3");
else if(e.getSource()==b4)
t1.setText("4");
else if(e.getSource()==b5)
t1.setText("5");
else if(e.getSource()==b6)
t1.setText("6");
else if(e.getSource()==b7)
t1.setText("7");
else if(e.getSource()==b8)
t1.setText("8");
else if(e.getSource()==b9)
t1.setText("9");
Dec 15, 2008 | Computers & Internet
Not what i wanted
easy all 4 pin dont matter 4 pin to all hard drives and cd roms ok big 20 pin or 24 to mobo smaller 4 pins floppies ok dont mater that its says p1 p2 3p that dont meen nothing ok 4 pin plugs main ones uuse on cd roms hard drives ok fans sumtimes
Jan 23, 2008 | Computers & Internet
Hardware & Accessories Logo
143 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
