Question about GE Washing Machines
Remove agitator ge washer wlse3150a0ww - GE Washing Machines
onthejob5130
  • 640 Answers
SOURCE: GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Posted on Jan 23, 2009
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: ge toploading washer will not agitate
Simply pull up on it very hard.
It will come off.
Posted on Mar 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: I need to remove GE topload washer agitator
Pull up hard on the agitator. It will come up.
Posted on Mar 22, 2009
SOURCE: ge super capacity plus washer. Mod wlse3150a0ww.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Posted on Jan 29, 2010
How to replace agitator
Agitator coupler GE front serviceable washer - YouTube
? 5:02
www.youtube.com/watch?v=4Rf4RO2MGeM
Nov 3, 2011 - Uploaded by theapplianceman Agitator coupler GE front serviceable washer ... How To Repair Washing Machine Agitator - Remove And Replace AgitatorDogs - Duration: ...
Sep 24, 2015 | Washing Machines
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    GE model WWA8320GAL How to I get the agitator to come off. Thanks for any advice art
    Please read this link below first before you try to remove the agitator.
    http://www.geappliances.com/search/fast/infobase/10002927.htm
    This link below will tell you how to remove the Agitator on the ge washer.
    http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
    Jul 07, 2011 | Washing Machines
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Apr 06, 2011 | GE WBSR3140DW Top Load Washer
    Coin stuck in agitator. how is agitator removed
    Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
    Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
    Jan 22, 2010 | GE 3.2 cu. ft. Washer
    Washing Machines Logo
    20 people viewed this question
    Top GE Washing Machines Experts
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
