Question about Canon PowerShot A530 Digital Camera
Unit won't power up even with new batteries
Upon pressing the on/off button lens opens up and green light and screen turns on for fraction of a second then off. Keeping the finger on the on/off button keeps the green lights on, lens deployed, and the screen on.Letting go will turn off green light, lens rectracts and screen off. During the process, when the screen is on, it has nothing except the "canon" word on it.
  • Canon Master
  • 4,738 Answers
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Jan 03, 2009
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Samsung S85 camera wont turn on. When the power button is pressed the green light flashes and the camera beeps three times than turns off. how do i fix it?
I quote the solution posted for another expert about this same problem...
My daughter has a Samsung S850, and returned from a weekend trip last night. She pressed the "Power" button and the blue light next to the button came on, as did the screen. The camera then gave a "buzzy beep" three times and shut-down. She decided the batteries were low and replaced them with ordinary AAA alkaline batteries, nothing special, and got the same result.
This morning I checked the voltage on the new and old batteries with a volt-ohm meter and found the old ones were low but the new ones were good.
I read this site and saw a comment that the camera worked after the lens was worked a little bit.
Upon a close look at the lens, I could see tiny grains of sand around the outside of the glass, so I got a wooden toothpick and gently worked the sand out with plenty of tapping on a solid surface to drop them from the area. I also worked the tip of a clean toothpick under what appears to be a soft rubber sealing ring on the outer surface of the glass.
After all this, when the "Power" button was pushed, the lens moved out and the screen lighted, and all the camera now seems to be working.
I should add that shortly after my daughter bought the camera, she lost some kind of metal or plastic ring from around the lens, and that left the "works" around the lens open to view: I can see two tiny screws the lens that are probably ordinarily covered.
Is the lens supposed to be covered by a curtain when power is off? From what I see, the lens is always uncovered. Maybe that lost ring held something else!
Its possible that
it needs repaired by samsung; You can follow the below link for tech support - http://www.samsung.com/uk/info/contactus.html
Hope this helps; send us you test comments.
Feb 26, 2011 | Samsung S85 Digital Camera
I have a HP camera CW450t camera and cannot turn it on with the power button on top. I know the batteries are good because I can turn on the camera with the review button and review the pictures that I...
I had the exact same problem. What I found out was that certain types of batteries have more power to power the camera and make sure the batteries are brand new because they might have been sitting in your cabinet or where ever and run out of power and not be able to open the lens or turn the power on, and the manual (disk) that came with the camera says not to take the batteries out if the camera's on and if your lens isn't opening properly it's because your batteries are low on power. Well I hope I helped. Bye.
Dec 27, 2010 | HP Cameras
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
My Samsung S850 Wont Turn On
cameras beep when it has a problem. most likely the lens get stuck or lens gear failed or motor drive gear to lens, or allot of other problems like it doesnt reconize the optical sensor.
look online for the beep codes and problems.
ty
hope I helped
Jan 27, 2008 | Samsung S850 Digital Camera
Canon PowerShot A530 Digital Camera Logo
114 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
