Question about Rowenta DZ9080 Iron with Auto Shut-off
Red light flashing on rowenta dz9080 but no heat
Why does my rowenta dz9080 not have a green light flashing
bestdarngood
  • 3037 Answers
SOURCE: Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Posted on Mar 29, 2008
  • 2318 Answers
It looks like the cord has a loose connection and will need to be replace.
nitrospawn
  • 290 Answers
SOURCE: rowenta DZ9080 iron yellow light flashes but iron
it is possible that there is a loss in contact in the iron you will need a local repairs man to do that for you
Posted on Apr 28, 2010
  • 10 Answers
SOURCE: only the green light lights up, dz9080 rowenta advancer iron
A small amount of White vinegar or some diluted dishwasher scale cleaner (calgon) added to the steam water then run it on steam setting ironing some waste fabric untill spotless.
Posted on Aug 02, 2010
tunde007
  • 2382 Answers
SOURCE: Rowenta Advancer, model #DZ9080, is
Hi, you need to check that power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If power is getting to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
Posted on Sep 06, 2010
How do I fix iron?
If there is no heat, then the heating element has opened and is in need of repair.
Aug 29, 2015 | Rowenta Advancer High Pressure Steam Iron...
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
My Rowenta DZ9080 has a flashing yellow light but no heat, can you help!
when I contacted rowneta about this they ask us to contact the repaire shop IN small appliance in NY I did mail them unit after stating the problem they have send me mail that They are unable to repaire the unit because of unavailability of parts and now they want additional amount to send me back the unit. Its just redicules to spedn 35% of cost to received unrepaire they could have told me before hand by model number and type of problem that they are unable to repaire This is really cheating on part of rowenta and repaire shops SO be carefull before you send it for repaire
Aug 20, 2011 | Rowenta DZ9080 Iron with Auto Shut-off
Lights come on but it don't heat up..
Sounds like a defective thermofuse. Rowenta doesn't encourage anyone to repair their product except their authorized service centers. Parts are not made available. Go to rowenta.com to find the nearest service center and call them.
Nov 07, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Only the green light lights up, dz9080 rowenta advancer iron
Aug 01, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
My DZ9080 does not heat up. The lights come on.
If it does not heat up but lights is on, the reason being is the connection to the heaters is open or disconnected. It might be due to rust(water seepage) or overheat issues. Why the light is still on, its because the tap the supply to the led before the connections to the heaters. Try dismantling it to check the connection but most irons now is difficult to dismanlte without breaking something
Jun 10, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta DZ9080 iron yellow light flashes but iron doesn't get hot
Apr 27, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta DZ9080 Iron with Auto Shut-off Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
