Question about Seagate SGT-Test (SGTTEST) Hard Drive
How do you do a hard drive test??? - Seagate SGT-Test (SGTTEST) Hard Drive
  • Seagate Master
  • 27,725 Answers
How to Run a Diagnostic on a Computer
After a while of using your computer, you may notice a drop in its efficiency.
This can happen when there are too many programs running at once or because some programs are hogging your computer's memory.
Sometimes, though, the problem lies much deeper.
With so many parts on a computer, it can be intimidating to fix, but Windows has built-in diagnostic tools that can run a scan of your system.
Before you run out and pay a computer technician, try fixing the problem yourself
Run Scandisk to check on the hard drive. Click "Start," then "Computer" (or "My Computer"). Right-click on your hard drive (usually "C:") and select "Properties." Go to the "Tools" tab and
Click "Check Now." Check the boxes labeled "Automatically Fix File Errors" and "Scan for and Attempt Recovery of Bad Sectors" and then select "Start."
Run the DirectX diagnostic tool to check for video card problems.
Click "Start" and then type "dxdiag" in the search bar. Press "Enter" to run the program.
You can look through the tabs such as "System," "Display," "Sounds" and "Input." at the bottom of each page will be a "Notes" section.
If the tool finds any problems, they will be listed there.
Run the Network diagnostic tool if you are having a problem with your Internet.
Click the "Start" button, then "Network," then select the "Network and Sharing Center" tab in the top frame.
Choose "Diagnose and Repair." Windows will automatically attempt to fix the problem and will then explain to you what it thinks is wrong.
Hope this helps
Posted on Oct 29, 2012
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
1)How to find and remove the hard drive on the IBM ThinkPad T22 2647. 2)The comp appears to start but screen is blank
hi
to remove the hard disk, remove screws from small hard disk drive door (loacted on back of notebook), disconnect the hard disk by removing two screws (if applicable) pull tab to remove disk.
OR -----
if you do eventually get access to your operating system , when computer runs normally ---
run this test ,, read carefully and follow instructions - go to this link and download the program first
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-70578
then follow instructions below.
Windows XP
  1. Click Start, select Search, then click All files and folders.
  2. Type hddquicktest_setup_60549818x86.exe in the search field, then click Search. This will locate the file you just downloaded.
  3. Double-click the hddquicktest_setup_60549818x86.exe icon.
  4. PC-Doctor for Windows will be installed on your system.
How to Run Lenovo Hard Drive Quick Test
Summary
Lenovo Hard Drive Quick Test is a diagnostic tool that tests the hard drives in Lenovo ThinkPad, ThinkCentre, and Lenovo 3000 computers running Windows XP or Vista released after January 2004. If you are experiencing issues with your Lenovo product, you may run this test to determine if your issues are hard drive related.
Running Lenovo Hard Drive Quick Test
To run Lenovo Hard Drive Quick Test from Windows, follow these steps:
1. Download the test to your computer.
2. Run the application install and choose the defaults. Once installed, the application will be placed under a "Lenovo Services" choice on your Start Menu.
3. If the application detects that the Lenovo System Toolbox is already installed, it will ask whether you want to continue the installation. This is because the new hard drive test is installed by default as part of the Lenovo System Toolbox.
4. Choose a drive if you have more than one drive.
5. Start the Test
Testing in process:
1. The test may take 4 to 6 minutes depending on the size and speed of the drive.
2. When the diagnostics are complete, a message will be displayed indicating that test "Passed", "Failed", or "further testing is required to verify the drive's proper operation". If further testing is required, start running the extended test. The test may take more than an hour depending on the size and speed of the drive.
3. When the diagnostics are complete the extended test, a message will be displayed indicating that the test Passed" or Failed".
4. If the test failed, contact Lenovo Support Center
Note: Lenovo Hard Drive Quick Test is included in http://www.lenovo.com/systemtoolbox
Lenovo System Toolbox is a full application of computer diagnostics utilities.
hope this helps
Nov 15, 2010 | IBM ThinkPad T22 2647 Notebook
It said problem on hard disk, install hard disk.. how to install where to get it my netbook has no dvd/cd compress HP mini
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. If the computer has two hard drives, you should select the multi-bay test option and test each drive separately.
  1. Plug the AC Adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test. NOTE: The exact wording of the option for your particular BIOS may be slightly different.
The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
  • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
  • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
  • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
Instruction on how to Install a new HDD
Please follow the link
Thanks
Proton
Sep 03, 2010 | Computers & Internet
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
Hard drive crashed
NOTE:
If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
Dreamkam
May 28, 2010 | HP Pavilion dv1000 Notebook
Problem with hp compaq nc8430 no see my hard drive Went I reinstall windown xp my hard drive it not present
Go into the BIOS setup (press f10 during boot process), then SYSTEM CONFIGURATION and disable SATA NATIVE SUPPORT. Try installing XP again and it should see your hard drive.
(If it will work then please vote for me).
Thanks
May 17, 2010 | HP Compaq nc8430 Notebook
Computer will only start in safe mode hp cue root and hp help and restore are not working? what is the best resolution? hard drive failure?
I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. To use the HP Hard Drive Self Test, follow the steps below. NOTE: If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If any test fails , contact HP for instructions on how to order a replacement hard drive. If all of the tests pass, the hard drive is not damaged. As a rule, HP does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
Mar 01, 2010 | HP Pavilion dv9000z Notebook
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    HP Pavilion Dv5-1008TU Hard Disk / Hard Drive not detected.
    The hard drive test could not detect the hard drive, indicates a faulty drive.
    Also if the drive does not spin up or is making clicking sounds then the it is definitely faulty.
    You need to buy a new drive.
    Mar 10, 2009 | Acer Aspire 5050-3242 Notebook
    When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
    if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
    Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
    1. Plug the AC Adapter into the Notebook PC.
    2. Press and hold the Power button for 5 Seconds to turn off the PC.
    3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
    4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
    5. Select Hard Drive Self Test
    6. Press the Enter key to start the test.
    The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
    If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
    Mar 07, 2009 | Acer Aspire 3680 Laptop
    Computers & Internet Logo
    46 people viewed this question
    Top Seagate Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
