Question about Coleman powermate 3250
I have a Coleman Powermate 3250 Generator that will not put out and power
I have used this generator before with no issues. Then one day I started it up and the were an AC power. Checked the Breakers and wires and all seems fine. Whats could be the issue?
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
  • 243 Answers
SOURCE: coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Posted on Feb 10, 2010
SOURCE: No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Posted on Apr 02, 2010
  • 905 Answers
SOURCE: want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
Posted on Jun 12, 2010
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 10 hp generator, not in use for 3 yrs. put gas , wont start. thanks for help.
couple things you can do . drain carb and put new gas in , check air filter ( take it off and try to start with filter off ) , open petcock , and finally take shroud off and sand the rust off the flywheel where magnets are . let me know what you find , xrsrule2@juno.com
Apr 10, 2009 | Coleman Powermate Powermate 5000W...
Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Feb 07, 2009 | Coleman Powermate Powermate 5000W...
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Sep 26, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
188 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
