Question about Lexmark X73 All-In-One InkJet Printer
Scanner was terminated abnormally & will not scan now, please help
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Runtime error abnormal program termination
Sounds like you have ran a scan on your drive and the software has become corrupt.
Download the utility from Seagate and try again
Feb 08, 2014 | Seagate Back Up Plus Desktop Drive...
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
How do i turn off auto enter on my symbol ls3603mx scanner?
from manufacturers site take scan code sheet, you will just find there programming scan codes, one for start programming, another to terminate auto entry and third to terminate programming. that is correct procedure if scannig is automatically set in scanner, if scanning is in your database on other hand, you need to re-write that bit which insert your code to database/spreedsheet automatically and change it to manual, as i do not know which of these method you use, i cannot be more specific.
try scanner first! usually scanner is programmed on automatic.
Jul 20, 2010 | Symbol LS3603MX
Scan bar code using motorola MC75
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Jul 15, 2010 | Zebra Symbol MC75 Portable Data Collector...
Scanner Canon 5010c
This is a known problem with the scanner. Use PixEdit to scan which comes around this problem so the scanning terminates OK after the ADF goes empty.
Dec 22, 2008 | Canon DR-5010C Path-Through Scanner
Acer Scanner S2W 3300U Download
give me the idea to download Acer S2W 3300U software.
Dec 16, 2008 | Acer Scan to Web 3300U Flatbed Scanner
E07-11 check scanner unit
you may check the sensors(home position sensors) of the scanner unit because e711 means abnormal platen scanning
Aug 13, 2008 | Panasonic Workio DP-2500E Copier
Does itsupport 1D linear laser scanner
This device has an Digital Imager (instead of laser scanner) which supports 1D and also 2D barcodes.
Feb 04, 2008 | Symbol MC9060-K Portable Terminal
Black output
This type of issue could be related to different sources. First step I would do is check to see if the lamp is coming on within the scanner, possible bad lamp. One other possibility would be the CCD failure, it may not be moving across to capature your film. Also, when attempting to scan does the scanner sound normal or abnormal. If abnornal sound is occurring then CCD could jammed/stuck hardware failure. Last step would be uninstalling/reinstalling your scanner software, check for updated drivers from the manufacture of your scanner. At this point if none of these suggestions helped then test scanner on a different computer system.
Sep 02, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
My 4 in 1 wont scan but does print
Before we give up on the scanning/copying ability of your machine. Try unplugging the machine from the wall and from the computer for at least a couple minutes. If that doesn't work, You may also check for a factory reset switch or reset mode you can choose. http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:94:0:0&os_group=WinXP&searchLang=en Last but not least. Uninstall the printer again, unplug it from the wall and computer. Make sure you restart the machine and even shut it down before trying to reinstall the drivers. The above site has a patch for the scanner. Not sure if its what may be ailing yours. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
