Question about Frigidaire FPHD2491KF Dishwasher
Frigidaire FPHD2491K won't start
When starting a load the Frigidaire FPHD2491K control panel seems to work as expected but the start/cancel button doesn't activate, and system goes back into standby. The water temp is above 120deg. What's preventing it from starting?
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
  • 1632 Answers
SOURCE: will not start. control stuck on glasses cycle. display states "39" cannot change cycle or cancel
Go to the fuse pannel and trip the fuse breaker off and then put it on again. It will reset the automatic cycle. Vitally
Posted on May 13, 2009
  • 415 Answers
SOURCE: dishwasher won't start. Control panel lights come
under the plastic door liner is the pcb timer and the white looking with 2 wires hooked to it needs replaced always unplug or shut off power to unit if working on it if you know how to use an ohm meter take a resistance reading if none replace the thermal fuse....
Posted on Aug 19, 2009
  • 6 Answers
SOURCE: frigidaire pld4375rfc2 dishwasher
don't buy this manufactors products the are not weel made!
Posted on Sep 28, 2009
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Posted on Feb 06, 2010
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Frigidaire FPHD2491 electronic buttons not working. Only China/Crystal cycle will light up and can be selected. All others do nothing. I checked the control lock and it does nothing. seems like the...
Hello bamspry - From what you are describing if only the China/Crystal icon is working, then the dishwasher could possibly be experiencing a communication problem coming from the main control panel or wiring failure. If I was in your position, I personally will recommend consulting a professional to move forward accurately and to assist with the repair(s).
Feb 24, 2013 | Frigidaire FPHD2491K Builtin Dishwasher
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire washer won't finish cycle
Hello Ellen Greer - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire GLFT294OES3 turns on, but after a few seconds, it goes to "No Spin" and errors out. The water won't come through and it just shuts off, please help!!!
To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
You may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
I am babysitting at my daughters house and I have the loc light on and I cannot get rid of it. I am trying to start the dishwasher and cannot get it to go.
look at the control panel there is a button that has a picture of a lock or a child by it, that is your child lock button, hold button down until lock light goes off
Sep 18, 2010 | Frigidaire FPHD2491K Builtin Dishwasher
Frigidaire FPHD2491KF Dishwasher Logo
29 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
