Question about Panasonic PT-47WX53 47" Rear Projection HDTV
My Panasonic 47 in wide screen PT47WX54J picture went to scrambled vertical lines then powered off. Power light flashes 5 times...any ideas what went out ?
SOURCE: Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Posted on Feb 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: television power light flashes on panasonic television
3 flashes is the error code for convergence failure. You will need to change both of your convergence ICs they are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair your self. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: My Panasonic CinemaVision 47" won't turn on.
Thats the error for the convergence. The following repair kit will usually repair that. The kit contains the parts and instructions with pictures on how to do the repair. Heres a link to the kit for your model. http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Posted on May 18, 2009
  • 11 Answers
SOURCE: Panasonic PT47WX54J is showing a red shadow behind words and pict
you need to go to your remote, look up menu. then select "convergence"...this will give you a "crosshairs pattern to align your "guns" ...it has three red, blue, and green.....try not to move the TV around too much....its knocking them out of alignment
Posted on Oct 01, 2009
  • 418 Answers
SOURCE: My 2004 Panasonic PT-53WX54J went to a blank screen
Probably DG circuit board.
Posted on Apr 14, 2010
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
PT-53WX54 picture went fuzzy then disappeared, sound is OK, there is a very faint vertical line about 4" wide. No falshing power light. Any ideas?
If you have sound---the faint band is towards the right of the middle of the screen I know which part is bad it is very common on these sets and about a 3 dollar part.
If you want the answer and complete details rate this solution as very helpful as I do this here for free.
SD TECH
Sep 25, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Oct 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Picture is compacted vertically in center of screen redgreenblue
your vertical hold is out on the tube. new tube is needed. cheaper to get a new flat panel tv.
Jul 19, 2009 | Samsung HC-P4752W 47" Rear Projection...
Power Light blinking 5 times
check the resistors near the
stk's. There are some reports that they get fried when the stk's fry....or the other way around. The resistor ratings are labeled on the resistors. 2.2, 82, 180 or something like that. Also check the board as you turn on the tv. See if any glow red.
Sep 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt47wx54j
hi there, there's a electronic parts defective. a capacitor at the video section and test the power supply section. ty
Jan 01, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Horizontal lines center of Panasonic HDTV
Usually there is a capacitor in the pump up circuit and/or an IC in the vertical circuit that causes this problem. Contact Panasonic at: http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001 To find a servicer in your area. This will give you an idea of the cost of repair. Hope this helps.
Jun 02, 2007 | Panasonic CT-27HL14 27" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
