Question about HP cp1700 Color Inkjet Printer
How to clean"pump stall" error
  • iman yaghoubi Nov 01, 2012
    hi dear my printer is cp1700 HP,once error in my printer it was" please replace red cartrige & red cartrige is missing " and on LCD red color level was low, but i pulling & put on in place any more, so it was "pump stall" error , i cleaning & washing electronic bord of under the cartrige place , but it was " pump stall..." and i dont put down this error yet
Why does my 1991 Ford Laser GL keep stalling?
possibly the vacuum hose from the top of the rocker cover or near that exhausts the fumes from the oil to the carbie is disconnected or block...or if it is automatic it could be that the transmission needs servicing.ie new filter and gasket kit bout AUD$20 and clean new transmission fluid AUD$40.. just drop the pan one side at time. catch the old fluid. when its empty remove the entire pan with care. then clean the pan and remove old filter. then insert new filter and o-ring. then line up new gasket on pan and bolt back in to specific tension. pour new fluid in to specification.warm engine in park to runing temp then check fluid level... this is all to remove the possibilty that it is the transmission and not the engine AUD$60 and 2 hours of your time..
Feb 20, 2013 | Cars & Trucks
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Whirlpool AWOD6727 washing machine displaying error code "F23". Help please?!?!
Could be a slow drain time issue. Excess wear makes it drain slow.
Mar 17, 2017 | Whirlpool Washing Machines
2000 ford taurus fuel pump
You may have a ground wire issue with the pump. If the current ground wire termination to frame or body is showing signs of corrosion, try clean the area and terminal down to clean metal and reassemble- then make sure the area is painted and topcoated. Primer is not water resistant even.
If that does not remedy it, wait until pump fails and be sure to replace the connector in the tank itself when the pump is replaced.
Dec 25, 2011 | 2000 Ford Taurus
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 21, 2011 | Frigidaire Washing Machines
The pump is not pumping water when in drain cycle and "Pump Blocked?" error is displayed. The washer has been drained and the pump cleared of debris (penny, toothpick and two small rectangular...
Hello & Welcome to FixYa
If you have cleaned it completely and nothing is blocking the drain pump assembly then it means that the drain pump is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jul 25, 2011 | Bosch Axxis WFL 2060 Front Load Washer
96 Olds Aschieva 3100 V6...car idles fine when cold in "P" and "N", but wants to stall in "R" and "D", and most of the time it does stall..if i let it stall 3 times...
have you had the fuel system cleaned as it could be dirt.also have you cleaned the throttle valve(plate)as when these get dirty it can cause this type of condition.it could also be a fuel supply problem like fuel filter,fuel pump,injectors.the ignition circuit could have a problem also like the coils,the ignition module,you don`t say if you replaced the plugs when changing the wires.it could also be the crank sensor or cam sensor possibility.this should be checked out at a shop if you can as some of these things need experience and equipment to diagnose.
Jun 29, 2011 | 1996 Oldsmobile Achieva
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
My printer has a "Pump Motor Stalled " message. It
Hello. First of all you have to "Reset the printer" to factory default. To do this, you have to press and hold # & 6 at the same after you push the "Power" button. Hold the # & 6 keys till to see the power led blinking. The printer will reset to defaults and give it 1-2 minutes to warm up and prepare its software. After this check if your printer is working properly. If not, open the access door and check if there is a paper jam inside(left or right) behind the cartridges. If not again, buy a Blower( a machine that blows air with a lot of power) and use it to clean the interior of your printer. After this buy some lubricant and insert it with attension where you see cogwheels. After all those things your printer will work without any problem.
Feb 07, 2011 | HP Photosmart C7280 Laser Printer
WL80T65C - error 245, can you please advise on this error?
The error 245 is a drain pump stall. Take the pump out from the bottom of the machine (2 screws) and clean it out. The resistance between the red and blue, blue and white, and red and white wires should be 16 ohms, if not, replace the pump.If the resistance is ok then clean the drain pump and drain hose to which the pump is connected.Clean it with normal tap water.Then refit it and check.In most of the cases cleaning the pump and hose helps.In some cases the pump has to be replaced/.----------- This will help.Thanks.Helpmech.
Jan 20, 2011 | Fisher and Paykel Washing Machines
HP cp1700 Color Inkjet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
