Question about Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw
Needing a starter pully or compleate starter for my saw
I need a starter pully or compleate starter for my saw . the pully broke where the pawls go where can i get parts, it seems to be n.l.a. from troybuilt by this part number 9228-md0701 im my book
Pull start not engaging with motor
Check the starter pawl spring inside the starter housing and see if the springs are broke.
Sep 05, 2014 | Garden
Mcculloch ms4018av
There is a pawl that engages the recoil starter with the power take off end of the engine. It is probably sticking. If you remove the recoil starter and pull the cord you should see the pawl swing out, then retract when the cord is released. If you take it apart clean out all the gummy grit and give sliding parts a coat of lubriplate which is a light, waterproof lubricant you can purchase in a small tube just about anywhere.
Oct 23, 2013 | Garden
The pull cord hasn't snapped it just wont recoil! is this an easy fix?
Sounds like the starter spring has broken, remove the three torx screws securing the starter and remove the starter, prise off the r clip holding the pulley and pawl on ( note the orientation of the clip on the pawl ) remove the pulley, the spring is in a cassette, remove the cassette and replace with new, refit the pulley, make sure the pulley locates properly into the hook on the starter spring, re fit the pawl and r clip, enter the cord into the cut a way in the side of the pulley, now wind the pueey around to tention the spring.
Apr 17, 2013 | Stihl Concrete Cutoff Saw Rewind Recoil...
Pull cord for starter is not catching?
There are starter pawls that catch the flywheel when the rope is pulled. They are plastic. You will need to disassemble the unit and remove the starter assembly to inspect the pawls.
Nov 11, 2012 | Ryobi Garden
My flywheel won't catch the pully for the handle starter, why?
Possibly broken started pawl on the inside of the recoil housing, better get your tools out, its not a tough job.
Sep 12, 2011 | Husqvarna 28cc Gas Line Trimmer
I just put a new starter pral in and it pulled once and now it won't catch again when you pull it.
The wire clip that secures the pulley also acts as a clutch, as the pulley turns the wire clip tries to stay still, and in doing so pushes the plastic pawl out, so you either do not have enough tention on the clip around the centre post, or the wire clip is not around the plastic dowel on the starter pawl.
Feb 13, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
Pull start and pawls with back plate for echo 602L
I think what you seek is listed here: http://www.echo-usa.com/documentation.asp?Model=CS-602VL&lang=E
See the "Starter and Magneto" print.
EchoUSA (all models)
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 28, 2010 | Echo Garden
What will a stihl 015 chainsaw do if one of the springs on the plastic deals on the flywheel are broke? would it cause the saw to rev then idle down. if not what would cause that
the plastic pawls on the flywheel catch the starter pulley to turn the engine over when the starter is pulled. the spring hold the pawls in, centrifugal force holds them out when the engine is running. the one that is broken may not catch and allow the starter to skip. That is an old saw and the fuel line may be collapsing due to being softened by the fuel.
Jan 11, 2010 | Garden
This is my second wild thing. I wore the first
Hello Ms Weem:
Will the starter cover from your first Wild Thing fit?
Have you looked at the starter cover on a different new Wild Thing (demo)? Is it like yours?
Are you releasing the starter rope with it extended?
Yours is the first problem of this type I've heard for your saw. There is no pulley guide or starter rope thimble I'm aware of. I'd think a small nylon or teflon bushing for the starter rope could be fabricated by a machine shop but it would be at your expense. HTH
Lou
Oct 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bosch Hedge Trimmer AHS 4-16 Starts now and
sounds like you will need to replace starter pulley in the starter cover assy and check that the starter pawls are free to move and the pawl springs are no broken or the pawls are frozen
but your problem is most likley starter pulley
remove the starter cover and check the starter pulley
worn or damage teeth on pulley may be quite evident
cheers pauly46
Sep 19, 2009 | Garden
Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
