Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LOOKING TO REPLACE BROKEN PART # 355JJ2019A
Draw cover broken at hinge. Need to replace the draw cover.
I was able to get online and go to parts.com and order the part. Figure I am not the only one that has had the draw cover to break. Noted that all of the next generation French door models no longer have that style of draw cover. The idea was good but not very practical.
Posted on Jan 06, 2009
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Hello sir, i have a problem with my copier minolta di 450. The problem code is c-0990. Plz help me!
Main Draw (large Capacity) has a problem open and close front door if the code comes back then you probability have a broken gear in the 3 draw lift system. Usually the gear gets rounded out in the center. gear is black and located behind several gears behind the front cover of the draw
Aug 28, 2015 | Minolta Office Equipment & Supplies
Broken lug bolt
no need to replace plate . just drive out the old broken stud . insert new bolt and draw into hole with the nut
Mar 16, 2014 | 2001 Toyota Tacoma
Minolta Copier EP 6000 copier error codes: C:C0010, C:C0992, C:C0410. Any ideas what these mean?
As for the C0992 code that deals with a paper draw fault, looking at the control panel do you see a small wrench located at the left hand lower corner. Touch it , it will take you to another screen when there open and close the front door, if the code comes back you have problem with main draw.
The C0410 is a problem with the very, bright lite under the big glass is bad. try to reset, open the front door to your left is a small access plate open and press trouble reset, if the code comes back replace the exposure lamp.
C0010 code main motor fault, remove the fuse unit the hot part and check for broken gears check the section where it goes look in the back for broken gears, remove the drum assy. check for broken gears, open close the front door to reset, If it comes back get a new main motor and or main control board,
Dec 03, 2010 | Minolta Office Equipment & Supplies
Can I get parts to replace broken hinge? I have an HP Officejet 6210 All in One.
In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Dec 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Need to replace broken lug bolt
If you have room behind the broken lug you can usually drive it out with a good smack of a sledge hammer. To re-install, use a stack of washers between the nut and flange and draw the lug into position. (plenty of oil on threads to avoid galling)
Apr 19, 2009 | Toyota Tacoma Cars & Trucks
Volvo 2002 s60 fuel door
My guess is that the hinge clips are broken - it's hard to see how it works after the clips are broken off. I purchased and installed a replacement hinge from Myswedishparts.com. I emailed asking for help and they provided direction, but it's pretty easy. Use a small punch to drive the centers out of the plastic attachement pins to get the old hinge off. Replace the hinge, press the center pins in and re-attach the door. There was a drawing on the referenced web site when I replaced mine, but I just looked and didn't see it. I'm sure there are many places to purchase the replacement hinge - that's just where I bought mine.
May 28, 2008 | 2002 Volvo S60
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
107 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
