Question about Panasonic TH-50XVS30U 50 in. Plasma HDTV
It's like my tv doesn't read USB anymore
Hi I moved my tv in another room and after that this problem came. It's like my TV doesn't read the usb connector or something - when i look for the usb on the screen there is no option for the usb. It comes like this: AV1 AV2 COMPONENT HDMI1 HDMI2 HDMI3 HDM4 TV _ _ _ _ change usually the USB comes right beneath the TV but it isnt there.
  • 1,238 Answers
Try to restore factory settings
Posted on Oct 29, 2012
danbusa
  • 185 Answers
SOURCE: I am trying to connect
You may need to run a channel scan or add the channels manually in your TV menu. If you need assistance please e-mail me at: daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Posted on Apr 27, 2011
tvtek
  • 1284 Answers
SOURCE: no picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: how do i get my
I do not have a Panasonic but it should have something to do with the input button on remote. Sequence thru...
Posted on Feb 06, 2011
  • 18 Answers
SOURCE: i have a 42 inch panasonic viera th-p42g10a. i
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Posted on Mar 03, 2011
Won't read any kind of disc it spins and stopped like 3 times and doesn't move anymore
Sounds like you later lens has been damaged or is dirty. There is a cleaning kit at Walmart. If that doesn't work, google a local repair shop.
Feb 16, 2013 | Video Game Consoles & Games
No channel set up
Hi, try pressing the "closed caption" button on the remote. I hope that works. If this doesn't work try getting your TV's SE-R0305 Operating manual and reading through it and it might be able to help you. You will be surprised at how much information is in the TVs manual.
Oct 07, 2012 | Toshiba SE-R0305 Remote Control
I have a 32LD450 LG TV it will only show picture or music options from usb no movies??
LG 32D450 LCD TV doesn't support video playback from usb. The USB 2.0 input of this particular model can only read jpeg format (photo/snaps) and MP3 format for music playback. please click the link below and see the technical specification and USB input.. http://www.lg.com/us/tvs/lg-32LD450-lcd-tv
Apr 17, 2012 | LG 42LC2D 42 in. LCD HDTV
I have sanyo lcd flat 32, how do i watch with using usb
hi,
Sanyo DP32648 doesn't have any USB port to which you can connect an USB device. One more thing in most of the TV's the USB port is used for the firmware updates and servicing purpose. If your tv has USB compatibility then try to use USB device less than 4 gb and should formated in FAT file system.
OK
Oct 28, 2011 | Sanyo DP32648 32 in. LCD TV
Samsung dvd-d530 doesnt play usb. Please tell me how to reset factory settings or original grid code.
i I have a problem with my samsung dvd D530, it doesn't read the disc or the usb anymore. i cannot even enter the settings,all I get on the tv screen is ''no option''. can anyone tell me how to reset it?until yesterday it worked perfectly fine.
Jul 30, 2011 | Televison & Video
My television screen has an orange tint that I cannot fix by using the menu adjustments
Hi, If you have florescent lighting it will have an effect on the TV. Move the TV away or in another room. if that doesn't fix it call a repairman.
Jun 24, 2011 | Akai Televison & Video
What do i need to make the built in tv work
Hi anker, you'll need a mb tv turner installed in the vehicle and your dealer or someone with the star diagnostic computer to unlock the tv feature for you. I've done it on a few s class before. Now that tv in the usa is digital, the analog tv turners doesn't really work here anymore however with a few modification you can hook a dvd player up to your command system.
Please take the time to rate my answer. Thank you.
Jun 16, 2011 | 2000 Mercedes-Benz S-Class
After moving, my Philips HDTV doesn't show normal picture anymore. I can hear the sound but all it shows is many different color at once shifting down just the top of the screen (and it will do this...
The tv have a colors wheel design into it tv.The tv is now having grinding noises or colors pattern mess up or tv flashes of Black&White within the color picture.Mean the tv colors wheel disc it is worn out and it is not spinning inside it motor axis anymore.If u are not mechanically incline,don't tries to change the colors wheel by ur self,will cost u more problems,than it worth trying to save some money by trying to do the job ur self.Hire a bonded tv Tech.to do the job.The tv part and the labors should cost u about $500.
Jun 14, 2011 | Philips 50PL9126D/37B 50" DLP TV
Sansui tv doesn't read USB video
The USB port on HDLCD4212 is only for servicing the tv. It will not read video.
Jun 13, 2011 | Sansui HDLCD-4212 LCD TV
I only get 3 channels--and none of them I want! Does this TV only work with a cable attached? Which doesn't make it portable!
If you live in the US and the TV doesn't have the newer ATSC (digital) tuner, you're lucky to get 3 channels! The only analog broadcasts left in the US are "low power" & "translator" stations. The old NTSC analog tuners in TV's from just a few years back have little to tune since broadcasters have been moved and changed from analog to digital as directed by the FCC in 2009.
I hope this helps & good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Axion Televison & Video
Panasonic TH-50XVS30U 50 in. Plasma HDTV Logo
204 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
