Question about Jenn-Air Microwave Ovens
My Jenn-Air JMC2430WS00 will not work and shows code F6E8
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
Aug 12, 2012 | Jenn-Air JMC8127DD Microwave Oven
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
Read-out shows F3
On a GE microwave, "F3" means a bad membrane keypad.
You can order a membrane keypad here and install it yourself according to this handy illustrated guide, or we can install it for you.
If the keypad is not available separately, you can order a control panel frame assembly here, which comes with a new keypad already installed.
But since this was posted under Jenn-Air, that confuses the issue. If yours is a Jenn-Sir, please post a new help request here on FixYa and include the full model number from the tag, or contact us for a free estimate and tips.
Aug 18, 2010 | Jenn-Air Microwave Ovens
Error code E-21 Jenn Air convection microwave
That code says to first check your oven temp. sensor probe connection and ohm it out with an ohm meter, it should read about 1100 ohms at room temp.
If thats ok, then it says the problem is your relay board.
If you need more repair advice help on your appliance, click
Here
Jul 07, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
707 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
