Question about Samsung Transform Ultra
My samsung transform ultra wont charge at all, when i plug it up, it turns on an cut back off until i take it off the charger, please help
SOURCE: Samsung upstage wont turn on period. It is dead
I just had to buy a new phone because my Upstage had the same problem! But mine would stay on for not even 5 seconds before turning off and it would just repeat. So I went into the Sprint store and they gave me the Samsung Rant for 50 bucks even though my new for two wasn't up yet. They don't make Upstages anymore so just go get a new phone all together and see what happens :/ The Upstage is a horrible phone. Im sotrry this isn't much help. Trust me, I did my research before I decided to go into Sprint because I thought I didn't have the option to get a new phone so I was googling everything and anything I could think of to figure out what the heck was wrong with the stupid thing. Hopefully you'll be as lucky as I was.. Good luck!
Posted on Apr 22, 2009
  • 298 Answers
SOURCE: my samsung SGH-J700 wont turn on or charge
Time to get the ribbon cable changed. You can do this yourself with some patience after buying the cable over ebay or get it replaced at a service centre for a very cheap price.
Posted on Jul 27, 2009
  • 66 Answers
SOURCE: Samsung SCH-U340 will not stay on or charge!
try to change the battery.
Posted on Nov 16, 2009
SOURCE: my samsung sync wont charge when plugged into the charger
i am having the same problem with my Samsung Sync (A707). I brought it into AT&T and it is neither the Phone, battery, or charger
Posted on Jun 17, 2010
  • 7 Answers
SOURCE: Samsung Tocco Ultra wont charge or turn on.
you have probly blowed your battery (aka) a battery leak check your battery to see in you can squese it if you can then its leaked and you need to buy a new battery from amazon or somewhere else for about 5 pound plus P&P
Posted on Jul 22, 2010
Battery charging failed,battery charger adopter ok
2 most likely possibilities in my experience: Phone plug has been bent/damaged this has happened to us on 2 phones.(most likely an internal wire). It will require service.
or
2) Cable or wall plug transformer have been damaged and charge is minimal or cut off (happens if the progs get bent or the wire gets kinked or over flexed or pulled hard.
Test each component with a friend's / co-worker's unit that you know is working (or at the store) Replace components as necessary.
Nov 23, 2014 | SAMSUNG GT E2652
New batteries wont charge???.
Possibly the charger is faulty.
Apr 15, 2014 | Jet 3 Ultra Power Chair
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
Samsung ez view baby monitor wont charge
Check the lithium battery see if it still good or the power transformer plug in?Take some rubbing alchahol soak it in a cotton ball clean the metal contact connections of the charger and the unit should help it to charged it better.
Jan 14, 2013 | Computers & Internet
My galaxy tablet GT-P7510 wont turn on its fully charged
Hold down power up button until it starts. It can take up to 30 seconds before it restarts.
Sep 29, 2012 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
My Samsung Transform Ultra phone keeps beeping as if I am plugging and unplugging the charger.
Flip the phone over after a charge. Put your fingernail into the little slot at the top center of the battery cover along the edge, and give a little twist. The batter over door will snap open a little. Grab it and remove it gently, and pull the battery out of the Transform. Count to ten, then put the battery back into the phone. Once the phone boots, the noise should be gone.
If this fixes your problem, you may have to repeat this process every time you take the device off the charger. If this does NOT fix the problem, then it is a short in your phone's MicroUSB connector that is causing the incessant beeping, and your phone will require either repair by Samsung (Boost Customer Service can give you the number), or replacement by you, with another phone of your choosing.
If you DO decide to repair or replace the phone, make sure to back up all of your data, photos, movies, notes and applications before you surrender the phone to anyone for repair or replacement. Every repair facility WILL do a factory data reset on your device before beginning to repair it, and the phone will come back to you in "new-in-box" condition, post-repair - with NONE of your info on it. Best way to back it up is to hit the Google Play store, and search "backup" - there are MANY online backup services from which to choose, and you can easily find one that will meet your needs and budget.
Jun 02, 2012 | Samsung sph-M930 Transform Ultra Boost...
Samsung transform ultra "charging" while not on charger
I had the same problem and eventually my phone just wouldn't charge at all. I took an old tooth brush n was cleanin the charging port with it then id blow it out n repeat and honestly after bout a half hour of doing this it is now finally charging.
Apr 16, 2012 | Samsung Transform Ultra
Jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
Apr 09, 2009 | Jet 3 Ultra Power Chair
Samsung Transform Ultra Logo
240 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
