Question about Toshiba Qosmio G25 (G25-AV513) PC Notebook
Cooling system failure for toshiba g25 av513
Have the same problem..how did u fix it? please help!
"A problem with the cooling system has been detected."
have you tried blowing out the internals of the notebook with compressed air? if the laptop is not actually overheating it could be a sensor problem. if that's the case you can more than likely disable these warnings in bios. hope this helps!
Jan 27, 2012 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
I hear noise coming from the back vents and I think it might be the processor fan. Is there a way to fix/clean it so that noise goes away and do I have to open it from the bottom? This is for Qosmio G25.
You probably need to replace the cooling fan, but you can try cleaning it out first. Get a can of compressed air or use an air compressor to spray pressurized air into the vent to spray dust out. If this doesn't work, you probably need to replace the fan. I actually found a guide for opening up the Qosmio G25 and replacing or cleaning the cooling fan. Check it out:
http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm
Sep 24, 2011 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio G25-AV513 PC Notebook charging connection on the laptop has wiggle room and now will not charge the laptop, how can I fix this?
replace teh dc input plug on the laptop. search ebay for the part, it should be no more than 10.00 (give or take shipping).
Jun 23, 2010 | Toshiba Qosmio G25-AV513 Notebook
Pci express error
Means you network card has somehow got weged out and its halfway in, halfway out.
You would have to open up the laptop and make sure everything is pushed in.
Dec 31, 2009 | Toshiba Qosmio G25-AV513 Notebook
Have a g25-av513 laptop with winxp mce sp3. what
The largest I've seen is 500gb.
Newegg.com usually has the best deals on drives. They also ship very fast and have great customer support.
Hope this info helps and please feel free to ask more!
Nov 28, 2009 | Toshiba Qosmio G25-AV513 Notebook
When i open my laptop only Q DISPLAY IN SCREEN HANG UP
Does the hard drive sound like it is spinning.
Did you try to go into the Bios setup?
Jul 27, 2009 | Toshiba Qosmio G25-AV513 Notebook
No hotkeys on my G25-AV513
Usually on Toshiba notebooks, they have a memory resident program on their call fkeys. If it isn't installed on your computer, you can download a new one from Toshibas support website.
Jul 20, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio G25 (G25-AV513) PC Notebook Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
