I have an Intertherm Mac 1165 pilot light is on and stays on but furnace won't light...bypassed the thermostat and replaced the thermocoupler....cleaned the lenses with a dry rag.....no luck any i
  • 2557 Answers
SOURCE: intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Posted on Jan 02, 2010
  • 221 Answers
SOURCE: i have a williams wall furnace model 5009622,and
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Posted on Jan 11, 2010
SOURCE: pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Posted on Sep 21, 2011
walterkunesk
  • 683 Answers
SOURCE: I have a williams wall furnace model # 2509612 and
Thermocouple bad or loose.
Posted on Oct 07, 2011
walterkunesk
  • 683 Answers
SOURCE: thermostat wireinghook up on furnace/where do they
Propane or natural gas.
Posted on Oct 24, 2011
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
Furnace won't turn on
What is the make and model# of your Furnace? And is it a pilot light, or a hot surface Igniter?
Dec 29, 2012 | Heating & Cooling
Pilot won't stay lit
as long as it is in the flame you should be fine
Dec 04, 2012 | Intertherm Gas Furnaces - M1GB-056-AA
I have a Intertherm mac 1155 propane gas furnace. The pilot lights, burners come on, blower comes on and in a few seconds the pilot goes out
Goes out or is blowen out ? could be a short pilot needs cleaning
Thermocouple could need replacing or the heat exchanger is split and the fan is blowing it out
Sep 14, 2012 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
We have an intertherm heating system, its probably 30 or more years old, and we cant see a pilot light, and we havn't been able to light it. the model is mac 1175.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Sep 27, 2010 | Intertherm Heating & Cooling
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
