Question about Ovens
NEFF U1422 How to remove front of control panel to renew spring on timer button
I need to know how to remove the front panel without damage
shaggyrat
  • 1224 Answers
SOURCE: How can I replace a damaged timer control knob?
i was reading up on this item and i came across section where they mentioned you have to purchase 4 complete different replacement knob boxes or panels
heres the link boy this product is having one heck of time
http://www.reviewcentre.com/reviews105062.html
Posted on May 09, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff U1422 oven overheating
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Posted on Nov 22, 2008
Maytag317
  • 1136 Answers
SOURCE: trying to unscrew bulb cover in a neff oven
Hi, DO NOT use WD40. Take a small towel or a rubber pad and grasp the lens with the palm of your hand. Turn it counter clockwise to release it.
It is very thick glass so, it should not break.
You might try to tighten it first. Sometimes a little nudge to tighten it will free it up.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on Jun 13, 2009
  • 401 Answers
SOURCE: Need Parts for older Kenmore Electric Wall oven.
check the sears website you can look up many parts there you will need your model #good luck!
ERIC
Posted on Jan 23, 2010
  • 196 Answers
SOURCE: my neff oven's handle has become loose. I cannot
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Posted on Mar 02, 2011
My neff oven b1322.1 is showing c03 code since moving , I now can't set the timer and clock etc can anyone help to solve this?
The C03 error indicates that the timer button is stuck or not responding. Check if the buttons can move freely; you may need to remove the rubber cover by prying it up. If the buttons move freely, sometimes the error can be cleared by unplugging the oven (or turning the unit off at the circuit breaker) for several minutes (up to 30 minutes). Turn the power back on. Then press and hold the Timer button for more than 180 seconds (3 minutes). Some people have reset the timer by setting the function selector to "interior light on" instead of pressing and holding the timer button.
If none of these actions work, then the timer clock needs to be replaced. If you add a comment with the full model number of your oven, I may be able to give you the part number. NEFF doesn't list a B1322.1; there are several B1322N1 models. There will be addition numbers in the model number and there may be some extra letters as well. See http://www.neff.co.uk/store/spare-parts to get a picture of where the rating plate is for your unit. That will have the full model number.
I hope this helps.
Oct 01, 2016 | Neff Ovens
Neff u1422 oven where is the element that needs tobe cleaned
behind back panel in oven held on with several screws.
Feb 20, 2015 | Neff Ovens
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
I need to remove the control panel to replace the Function Selector (knob) how do I remove the panel? Thanks
HI
you dont need to remove panel to replace, it literally just pulls out from the front as a complete assembly you may find using the edge of a teaspoon helps to draw it forward without marking the steel use the curved bowl of the spoon against the steel.
if the knob is damaged from heat escaping (melted) make sure you grill with the door closed.
Feb 22, 2011 | Neff B1421 Electric Single Oven
I need to change my neff oven u1744N0GB selector switch. I have a new one, but need to know how to change it out.
pull of control knob first, remove oven from housing and remove top panel undo 2 screws holding selector to fascia withdraw it back into top and change wires there will be quite a few dont get them mixed up! reverse to reassemble.
May 20, 2010 | Neff Ovens
Neff fan oven dead. Where do I look next? I've
this could all so be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 17, 2009 | Neff U1721 Double circotherm Electric Oven
Trying to unscrew bulb cover in a neff oven
no WD-40, turn of the power, break the bulb and remove the base with pliers. More than likely there is dielectric corrosion between the base and the socket and this makes removal next to impossible
Jun 13, 2009 | Neff U1721 Double circotherm Electric Oven
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Hi
Good luck
Nov 22, 2008 | Neff U1421 Double circotherm Electric Oven
Dec 01, 2007 | Neff U1661 Double circotherm super...
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
