Question about Frigidaire ATF6000ES Front Load Washer
Cleaning the coin catcher on agltf2940fs22 - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello - To check for a restriction in the drain line you will need to follow the steps below:
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer).
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps).
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Posted on Nov 01, 2012
We have a Fisher and Paykel Excellence 7.5 SmartDrive 9. I think we lost wedding ring through it. Do these machines have a coin catcher in them somewhere?
have a look under the machine where the tub hose goes to the pump
the catcher is in that hose
the tub hose will go in the top and the pump hose in the side so that any items drop to the bottom and are not put through the pump impeller
Mar 16, 2017 | Fisher and Paykel Washing Machines
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FTF2140FS Front Load Washer /...
GETTING ERROR E2O
This is a slow drain problem; remove the lower front panel, remove the pump and clean out the pump and the coin catcher and it will be fine. To access, remove the two screws at the very bottom of the bottom panel and push down and remove , the pump sets just inside.
Hope this helps.
Jun 12, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain, burning smell on rinse cycle. appears to be spinning just not draining
Check the 'coin-catcher'. It's a small compartment in front of the pump. It's supposed to catch all the big stuff (coins, nails, screws, etc) before it damages the pump. Sometimes lint and other items will snag in the coin-catcher and clog it up... Once it clogs, it will not allow enough water to go thru to drain the machine. I would not use the machine until I got it fixed (or looked at by a repairman)... the smell you're getting could be the pump not getting enough water thru and burning itself up....
Apr 12, 2011 | Washing Machines
Where is the filter on a whirlpool duet washer?
Unplug the washer. Remove the bottom front panel, usually three screws. You will see a round plastic piece that screws into the motor pump assembly, in the front center of the washer. Put a couple of towels down, unscrew this part, and remove it. This is the filter-coin catcher on the duet. Clean it out every 3 months or so. This is mainly for large items, so the easiest way to keep it clean is to just make sure there is nothing in your pockets. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Dyson coin compartment problem
try this push red clip up THEN turn to left the coin trap window,pull pipe firmly off from inside,clean gunk out,replace pipe pointing downreplace door by aligning notches turn to right 1 complete turn,if it feels tight turning TRY AGAIN until it feels smooth to turn.
Dec 03, 2008 | Dyson Memory CRO1 Front Load Washer
Washer wont spin
either a bad motor control board or your coin catcher is full of stuff. i would check the coin catcher first. open the front panel and you can see the pump the coin catcher is the part that comes from the bottom of the tub to the pump.Careful when you take it out there will be water in it and you will have to be ready with a towel or shop vac. put it into drain first before taking apart. it will not drain all of the water.
Oct 31, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
43 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
