Video graphics My PC is on sleep mode, when I wake up I do not get an Image on the monitor as usually, to get the image again I need to restart the Pc.
  • 2,878 Answers
It's the nature of sleep / hibernation mode. Try removing hibernation and set to home / office. It's like we want use this option, but MS and hardware never really sync. What I'm trying to say, it never seems to work as it should.
Posted on Nov 02, 2012
SOURCE: sound and video problems toshiba paas8-02000u
i want to down load sound and vga drivers of toshiba pass8-0200u
Posted on Jun 19, 2008
dante777
  • 623 Answers
SOURCE: Cannot show laptop image on external monitor via Svideo connector
If you want to use your TV as an external monitor, you have to connect them via VGA (top) or DVI (bottom) cable.
Which connections does your Philips monitor have?
Posted on Jan 05, 2009
cpenzes
  • 1102 Answers
SOURCE: PC won't wake up after Hibernate, Standby or Restart
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Posted on Jan 12, 2009
Sameeraryan
  • 82 Answers
SOURCE: computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
Posted on Jan 14, 2009
BubbaGuru
  • 70 Answers
SOURCE: Can't wake up....gone into sleep mode...how do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
Posted on Mar 21, 2009
Monitor slow to wake up
A computer uses sleep mode to save power and save certain key functions so that users can resume work quickly without waiting for the computer to completely restart.
There are usually at least two types of sleep modes: an ordinary mode in which the current state of the computer is kept operational, and a deeper hibernation in which current settings are saved to the hard drive.
When a computer does not leave the sleep mode, there is most likely a problem with power settings.
Power Button Use
Some sleep modes, especially the hibernation modes, remove the ability for the computer to sense outside movement.
If the user puts the computer into hibernation, then typing on the keyboard or moving the mouse will not wake it, even if these actions work in a light sleep mode.
The only way to wake the computer up is to press the power button.
Power Settings
Computers have power settings that tell them when to perform certain actions, including powering down and going into sleep mode.
Normally, computers will do this automatically when they have low battery power, but if the settings are changed it is possible the computer will only exit sleep mode when connected to a power adapter.
Users can change power settings themselves to more appropriate levels, if necessary.
BIOS Settings In BIOS (basic input/output system) mode, a PC shows not only the last actions that triggered the computer to go into sleep mode, but also what wakes the computer up from sleep mode.
Typically several devices, including keyboard and mouse movement, are listed.
However, if the computer is not programmed to wake up from sleep mode when these devices are used, it will stay unchanged. Users can add or remove devices from the BIOS system itself.
Vista Problems
Microsoft Vista has been known to develop several errors associated with the ability of the computer to wake up once it has gone into sleep mode.
If the user has Vista, it is possible an internal error, possibly connected with the USB ports, has caused the computer to remain in sleep mode.
Users can fix these malfunctions by downloading "hotfixes" from Microsoft's website.
Video Card or Screen Problems
If the monitor refuses to wake up from sleep mode but all settings appear applicable, then the problem could be with the video card or the screen itself.
In this case, the computer is resuming activity but the monitor cannot show it, so it looks like it is still asleep.
The user should make sure the monitor is working properly and make sure the video card is not malfunctioning.
You should also check ram Hard Drive & vga lead
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Aug 11, 2013 | HP Computers & Internet
Sleep mode
well to wake it up you usually have to press a key(any key) to wake it up, try this video on removing the ram and see if it helps:
http://www.youtube.com/watch?v=jBIN6tNyfMY
Hope it does : )
Apr 15, 2012 | Apevia Computers & Internet
Monitor is changing colors and won't wake up
This problem should not be only with your monitor, but also with your video card. You might have left one image sitting for long hours. There is no specific solution, but for Lcd users, you can try this. Leave the monitor off for few hours without any connection, maybe power chord or vga/dvi/hdmi cable. If this doesn't fix then the problem must be from your video card. You can try the monitor on another system to make sure, which one is the culprit. Your last choice is to reset the bios, to do this, remove the bios battery and leave it for few minutes outside (2 mins will do) and put it back. Reboot your system, this will fix your problem. Good luck. Thanks for using FixYa.
May 31, 2010 | ViewSonic VA721 17" LCD Monitor
After waking from sleep mode, monitor resolution is a mess!
Try reinstalling the graphics drivers. and possibly a different graphics card.
Apr 14, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
Not wake from sleep or hibenate
Usually, to wake from sleep pr hibernate, you just need to press the "Power" button of your laptop. It will not turn it off or restart the laptop if it is in the "sleep" or hibernate mode. Pressing any key usually wake it up. The default way is to press the power button as if turning it ON for the first time.
Feb 11, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
How do I wake up the monitor when it goes to sleep when not used for a short time.
slapping it around usually works. "just a joke!"
tapping a few keys on your keyboard and moving the mouse will usually wake the monitor from sleep mode.
Nov 11, 2009 | Office Equipment & Supplies
When screen comes out of screensaver/sleep mode,
It's a bad LCD screen or bad video card. If its a laptop, try to hook an external monitor to the video port in the back and see if it has the same problem. If it is the same problem, then you know its the video card and not the monitor screen. If you have a desktop PC that has this problem, its most likely the video card. First try removing the monitor and trying it on another computer to see if the monitor is bad. If not, then remove and replace your video card and restart. If same problem, replace video card with a new one.
Sep 16, 2009 | Computers & Internet
Monitor went to sleep and won't wake up
It sounds like a driver issue, but more likely the monitor driver, not the video card, since the other monitor works properly.
If you go into the video properties, check the monitor settings. You should be able to switch it to a generic monitor. You also need to make sure that you have the correct monitor refresh frequency set. If you have a mis-match, the video card could send signals at a rate the monitor can;t handle, which is why it won't "wake" even after a reboot and might need to be unplugeed to get it to come back on.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
