Question about LG 47LG60 LCD TV
Sometimes this TV turns on and has audio but screen stays black until it is turned off and then back on, sometimes more than once.
  • Jack L. Tapp
    Jack L. Tapp Oct 29, 2012
    Back2life, are these problems easily addressed and or cheap to fix?
  • Back2life Electronics Oct 30, 2012
    If it is indeed faulty capacitors, they are easy and cheap to replace if you have soldering skills.
  • LG Master
  • 933 Answers
I would suspect a problem with either the inverter circuit, or 24vdc circuit. I would start with checking the power supply capacitors. Look for any with bulging tops. Research shows your set is from the 2008 era, many sets from that time were built with cheap Taiwanese capacitors. I've repaired quite a few of the older LG LCD with your same problem. They all had faulty capacitors in the power supply.
Posted on Oct 29, 2012
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a 2007 LG 32 inch flat screen TV model
It can be cold solder joint in the power supply or component failure after heating up. You should do this when the screen is black out to help narrow down the problems.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 11, 2010
welcomejee
  • 10594 Answers
SOURCE: My LG 50PC5D has a hard time turning on. when
It seems issue with power supply board and most probably few electrolytic capacitors are dried up and causing problem.
Qualified local tv repairman visual check is needed to confirm the reason of problem as he will test/ check output volts of power supply.
If this tv is 3-4 years old then problem would be in power supply board as mentioned above.
Let me know if you have additional question.
Thanks.
Posted on Sep 26, 2010
  • 2187 Answers
SOURCE: LG 42lb5d has audio but no picture.
They may have missed out the power supply circuit. There may be loose solders or bad parts. You may have eliminated other parts which may have caused the problem when the service center replaced the parts. Inspect those that you still have remaining for leaking capacitors, loose parts or loose solders.
Posted on Oct 27, 2009
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Screen goes black
here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 08, 2017 | Televison & Video
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
LG 47LG60 LCD TV Logo
228 people viewed this question
Computer Repairing
Computer Repairing
