Question about E-Machines eMachines Desktop PC
Says low on meomry shut down running programas and restart
  • joecoolvette
    joecoolvette Oct 29, 2012
    You need more Ram Memory. If someone on here states just increase your Virtual Memory, don't do it. Windows allots how much virtual memory is needed, and will reset back to where it was anyway. (Rule of thumb is Virtual Memory is 1-1/2 times the amount of Ram Memory) What is the model number of the eMachines? Post back in a Comment.
    Problem Solver:
  • 5 Answers
The problem is your memory, you have used maximum memory on your machine, the program you are running requires certain amount of memory to function properly, it is advised that you clear your utilization of memory like, deleting files you don't use or files that are duplicated, another solution is to upgrade your memory or add more RAM to your machine for better speed performance.
Hope you find this helpful.
Posted on Jul 19, 2013
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
Same problem toyota D4 engine
Fuel injection cleaner and get better gas.
Jul 15, 2015 | Toyota Cars & Trucks
It starts easy and runs for about 10 minutes and cuts off. Have to wait 30-45 min. to restart with the same cutting off problem. Have always had a problem with restarting even when I shut it down on m
If your oil is too low or even a little bit low or if your machine is sitting on an incline, it will start and run until the oil is dispersed within the motor. Spreading the little amount of oil that is in there all around the inside of the motor would then reduce the amount of oil that is "sensed" by the "low-oil safety shutoff" switch, which would then shut down the engine. Its possible that your "low-oil sensor switch" is bad. You can test it by unplugging it. Just look for a wire that runs from your ignition switch or ignition coil to a sensor mounted on the engine block somewhere. Usually, it just unplugs right at the sensor. Simply unplug it and crank the engine and if it keeps running, then you know you have a bad switch (if you've topped off the oil, of course!).
Jul 07, 2014 | Ridgid Pressure Washer. 3000 psi 2.6 GPM...
Low freon than low oil pressure than shuts off and restarts going down the road
Replace the oil filter as it is clogged very cheap fix. I hope this helps.
Sep 04, 2012 | 1997 Cadillac DeVille
2002 toyota solara idles low and shuts off, engine was just replaced
Try this
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jul 03, 2012 | 2002 Toyota Camry Solara
Runs for awhile shuts down and will restart but will run awhile and shut down
Check your oil, you have a low oil sensor on your unit and if the low oil sensor will shut the engine down,
Aug 28, 2011 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Meomry space not enough but there is a memory card
Check whether you have selected the default storage as memory card,,This should solve your issue
Dec 16, 2009 | Nokia N92 Cellular Phone
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
