Question about Husqvarna Garden
Husqvarna 325L has no fire, Installed new plug
No fire at spark plug, Installed new plug will not start
  • Husqvarna Master
  • 7,482 Answers
Hi jerry
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: You should also check for carbon build-up in the exaust,as it can have an effect on starting and running of the engine if the carbon build-up is heavy.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 30, 2012
3 Suggested Answers
  • 42 Answers
SOURCE: spare parts
I have many different web sites that you can find parts at. Here are a few of the best:
www.jackssmallengines.com
www.outdoordistributors.com
www.m-and-d.com
Let me know if you need any help finding your parts. Thanks.
Posted on Apr 04, 2009
  • 202 Answers
SOURCE: No Spark - Husqvarna 125R Trimmer
Check the wire that goes to the "OFF" button. See if it is by chance loose or cracked allowing a short. Beyond that, it would probably be the coil, but I would lean towards some type of a short, especially if you know the plug is OK.
Posted on Jan 10, 2010
Husqvarna 359 Won't fire. left it for 2 days, fired right up this time. Idled high so: snapped off the L/H jet stoppers (emission regulation). adjusted low jet, went for H jet, kept trying to die as I let...
You need to pressure test the carb, if the needle is leaking you will never get to run well, if you have fitted a new rubber tipped needle and it still leaks you will have to replace the carb, the later carb was a Zama rather than the Walbro, it made the saw run so much better.
Sep 16, 2013 | Husqvarna Garden
Will not fire
Do you have a spark.? Even a new plug wont spark if you have a damaged switch or ignition module.
Spark - Fuel - Compression. If you have all 3 it should fire.
May 24, 2013 | Husqvarna Garden
New plug no fire in the ingintion
The ignition unit can fail at any time, before replacing try removing the top cover and pulling the plug leed away from the cylinder, i have seen the leed wear against the cylinder and short out,also check the wires that go down to the unit, these can also short out, it is not a simple task to change the ignition unit, you need to have all the from end off the machine to get to it
Oct 28, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
Husqvarna 325l-x won't stay running only runs for about 5 min then stops
The 325 engine unit is a very reliable engine, the things i have seen over the years are, cracked and leaking fuel hoses ( the fuel attacks the material and crazes the pipes ) some ignition unit failures ( when it stops check to see if it has lost its spark, by removing the plug, resting it on the cylinder and cranking the engine ) fuel tank breather in the filler cap ( when it starts to die, try slackening off the filler cap, if it picks up again, replace the cap )
Oct 02, 2011 | Garden
I bought a Husqvarna YTH2348 this past summer (may 2010). It ran great until this fall when I got some bad gas. One spark plug fouled out so I installed new ones. I ran it for a while then checked the...
I would start by switching plugs. Then does the wet warm one get hot and does the hot one now stay only warm. If the same plug stays wet, replace it.
If the same cylinder is not firing, check the wiring to the plug. Check the coil wiring and coil for spark to that cylinder.
Nov 30, 2010 | Husqvarna Garden
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 240 want start at all
Sounds like the ignition module or spark plug. The ignition module is what controls the spark plug that gives your saw the firing capabilities. Before you purchase one of those, replace the spark plug and see if that works. The 240 is a newer husqvarna; so I am skeptical to say it is the ignition module. However, any new product can have a bad part on it.
Your saw may have gotten flooded and won't start. Make sure your gas mixture is 50/50 gas to mixing oil. Always use fresh gas. If you make up gas and don't use a whole gallon at a time, put some fuel stabilizer in the mixture; so it will still be fresh the next time you use it.
Oct 28, 2010 | Husqvarna Chain Saw 18" 450 Model...
Husqvarna Leaf Blower won't start
yes, it is. i suggest checking to make sure the plug is firing--you can check by removing it, plugging it back into the plug wire and resting the threads of the plug on any ground--usually right outside the spot where the plug screws in. have someone pull the cord while you see if the plug fires. DON'T touch the plug while the engine is being cranked. also, even if you see a spark, it may not fire inside the engine. if the spark is weak, you may want to put in a new one.
May 11, 2010 | Husqvarna 28CC Handheld BlowerVac
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
64 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
