Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
I have a Kenmore Wispertone 300 cannister and I am trying to access the motor. There are four screws shown in the parts diagram. I need to remove the plastic on/off pedal to acess two screws. How do I release the pedal?
  • jjst Apr 16, 2009
    I have the same prolem! Followed paynomores advice and got the two screws under the cord pedal! But how do I get to the front two they appear to be under the bag/tool compartment hinge arems, How do i remove the bag / tool compartment hinge arms?
  • 4 Answers
I just encountered the same problem on a Whispertone 116 last evening. If it is the construction same as mine, there are four flexible plastic retainers molded into the top cover in the gap between the pedal and the motor cover. These are on the hinged side of the pedal. All four retainers must be bent in toward the interior of the vacuum simultaneously to release the pedal. A screwdriver does not work very well for this. What worked for me were four metal bars about 3/8" wide X 1/8" thick X 1-1/2" long. The pieces I used were actually the snap-off ends of some hanging file rails I found in my basement. Insert the four bars at the four retainers. They should fit snugly as they must push the retainers past the hinged portion of the pedal. To remove the pedal, rotate the pedal up in the same direction as the spring is pushing and it should come free from the motor compartment cover at which point you can access the other two screws. I suspect Sears has a special tool with four tabs to perform this trick in the repair center. Good luck!
Posted on Mar 11, 2009
Accessing the motor
Hi There,
This should help you get into the motor compartment in the back to access your motor. I hope this helps you.
I have uploaded parts diagram of your model below so that you can follow along:
Step 1. Open up the tool lid as if you were going to remove the dusting brush or crevice tool from the top of the vacuum cleaner Once the lid for the tools is open, simply grab the two arms at the base of the lid, and pull forward towards the front of the vacuum where the bag connects. You'll need to remove the tool lid completely from the rest of the vacuum. You may have to lift slightly upwards while pulling forwards to remove the lid.
Step 2. After you've removed the tool lid, now open up the lower part of the tool lid that covers the vacuum bag (Part 29 in diagram above). While this cover is open all the way, grab the two arms on this part as well, and pull towards the front of the vacuum where the bag connects, and slightly upwards, just as you did to remove the tool lid. Remove the vacuum bag lid completely from the vacuum cleaner as well.
Step 3. There are two visible screws that are now visible (The screw listed as number 16 that's directly underneath of the number 36) on the front corners of the motor housing. Remove both of these screws that are in the front corners of the motor housing.
Step 4. There are actually two more screws that are hidden on this model, that are located underneath of the foot pedal that retracts the cord reel. You'll need to now remove the foot pedal from the vacuum cleaner (part 36 on the diagram). In order to do this, use a flat head screw driver to pry off the foot pedal. Insert the flat head screw driver in the front of the pedal where the pedal meets the motor housing. There are 4 tabs that hold this pedal in place. Usually if you put your flat head screw driver in the middle of the pedal where two of these tabs are right next to each other, the pedal will come off right away. Insert your flat head screw driver where I have circled red, these are the two tabs that you want to pry off. Simply push towards the rear of the vacuum while the flat head screwdriver is inserted in between the foot pedal and the motor housing:
Step 4. Now that you have the foot pedal off of the canister, simply remove the two now exposed hidden screws (oh yea watch out for that spring that's underneath of the pedal! remember to put this back when putting the pedal back), and lift straight up on the motor housing. You'll now have full access to the cord reel so that you may push the cord back through the hole in the rear of the vacuum cleaner.
Please feel free to use the Clarification Request form here on the repair page if you have any questions, or need some further help in accessing the cord reel. If your cord reel has gone bad, we do carry all the parts for your vacuum, and we'd be more then happy to provide any part that you may need. Here's a link to the bags for your vacuum on our site, just in case you need to purchase some:
Kenmore 5055 Canister Vacuum Cleaner Bags, 9 Pack.
I really hope that this helped you. If you have any further questions, I look forward to hearing from you. If this was helpful to you, please be so kind and return the favor by rating my repair helpful. You may do this by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is really what keeps repair professionals like myself continue providing free repair services and it's greatly appreciated.
Thanks again,
Chris Jones
GoVacuum.com
Apr 11, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
HOW DO YOU CHANGE BELT CANT SEEM TO REMOVE BOTTOM TO GET TO IT KENMORE WISPERTONE 116
The top cover to the light lense pops off at the ends. When you get that cover off then you will see 2 screws that are by the swivel neck. Take those out and then the whole body top cover comes off. That will get you into the roller brush and belt area of this machine.
Dec 11, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Model 116 Cannister Vacuum.Trying to get into motor area. Think belt is worn out. I have removed the front two screws under the hinged cover, but can not remove cover over motor.. Still attached at...
Under the cordwinder actuator button, are your other two screws. To remove this cover, take a flat tipped screwdriver and , very carefully, find the "tabs" (there are two) both on the front section under the button. Then, Carefully, press them in and back and up, in that order, one at atime, or both if you can. Your button should pop off, it can be a bit tricky, I know, it feels like it could break. But don't worry, they usually don't break. If you think that there is a problem with your belt, there is no reason to be accessing the motor compartment, for there is not a belt anywhere except the power nozzle, and if you press the circuit breaker/reset switch (while unit is running) located on the power nozzle, this will often solve problems with your belt. I hope i could help fixya! Let me know, thanks! Rene (the Vacuum Doctor)
Nov 18, 2009 | Vacuums
Kenmore 3.9 with power-mate Model 116 2839581. Can't locate screws to allow cover removal for access to motor
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
Kenmore PowerMate cannister: Reattach cannister floor piece.
You need to open the head by gently squeezing the light cover housing and lifting it off. There will be two screws underneath and once removed the lid will lift off and reveal the area where the pedal installs.
Sep 02, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
I am trying to remove the motor in my Kenmore canister vaccum but cant seem to figure out how to get it out.
Without the model number, I don't know which model you have. But you can go sears.com, click on the parts link, then put in you completer model number, choose the cannister or main unit, a parts list and a picture diagram will come up, you maybe able to tell from that how it comes apart. Or get me the model number for me to look at.
Mar 15, 2008 | Kenmore 22812 Bagged Canister Vacuum
Vacuum base removal-kenmore whispertone 300
Most of these you have to take off the cover on the back end where the cover retrack button is. Usually it has a catch, 2 on each side, use a screw driver, pry up near each corner to release it, then you can get to the cover over the moter and cord reel. Remove the 2 screw and put up and out.
Jan 14, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
367 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
