Question about Maytag Dryers
Maytag neptune dryer model mde9700ayw rear drum felt is off ,making the drom loose.cant find replacement felt online
  • 438 Answers
You can purchase new felt from most appliance parts suppliers , in your area that handles the Maytag devices.
Posted on Oct 28, 2012
  • 262 Answers
SOURCE: Maytag dryer neptune felt at rear of trum came out
you have to buy a new one if the felt seal is still good use contact cement on the drub and seal to put back on with need any more help let me know
Posted on Jan 17, 2008
SOURCE: Maytag Neptune MDE9700AYW
I AM IN THE PROCESS OF REPLACING THE DRUM ALSO BECAUSE OF IT BEING BROKEN RIGHT WHERE THE GROOVE IS IN THE BACK OF THE DRUM THAT RIDES ON THE ROLLERS.
HERE IS THE WAY I AM APPROACHING IT: THE OLD DRUM IS OUT - NOW I AM INSPECTING THE DRUM SEALS AND ROLLERS - SINCE THE OLD DRUM IS ALREADY OUT YOU CAN SAVE YOURSELF ALOT OF HEADACHES BY REPLACING THE DRUM ROLLERS, FRONT AND REAR DRUM SEALS, AND THE BELT ALONG WITH THE NEW DRUM. I WOULD ALSO TAKE ADVANTAGE OF THE OPEN SPACE TO GIVE THE DRYER A GOOD CLEANING AND VACCUUM PRIOR TO THE NEW DRUM INSTALLATION. BE SURE NOT TO FOLD THE REAR SEAL OF THE DRUM DURING RE-INSTALLATION. TAKE YOUR TIME AND DOUBLE CHECK EVERYTHING AS YOU GO MAKING SURE THE DRUM RIDES NICE AND SMOOTH ON THE ROLLERS AND THE SEALS ARE FLAT ALL THE WAY AROUND. I HOPE THIS HELPS YOU TO NOT HAVE ANY FURTHER PROBLEMS FOLLOWING YOUR NEW DRUM INSTALLATION.
JIM - MR MACHINE DOCTOR
Posted on Oct 04, 2008
heatman101
  • 43501 Answers
SOURCE: Maytag Neptune Dryer makes loud noise while drying.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ergfgfjk
Posted on Sep 29, 2010
oldTech2332
  • 2341 Answers
SOURCE: is there something else i
On older maytag dryer's the felt seal wasa seperate part and not part of the drum..the problem is i do not know if the drum on the newer and older dryers is the same diameter they look similar in size but if it isn't exactly right may leave a gap where the clothes will get caught in...however the part number for that seperate felt seal is 314820
Gene
Posted on Aug 24, 2011
mc1bean
  • 3053 Answers
SOURCE: Maytag Neptune dryer model MDE9700AYW
Hello, savinglives I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
My maytag neptune model mde5500ayw make a sound like metal grinding, comes and goes, it looks like the felt liner in the back is loose in one area. Is this the cause of the bloody awful noise?
If the noise is intermittent then most likely the loose felt is not the best problem. More likely is the rollers that support the drum. You can take them off clean and oil with a good bearing oil and that might work or you can replace them if they are too worn
Oct 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Is there something else i can use to replace the felt seal without buying a whole new drum on a maytag neptune model MDE9700AYW
Gene
Aug 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Felt belt found inside of drum
Hi - these are used to minimize the metal to metal contact of the drum & housing.
One will need to remove the top & front panels to gain access to remove the drum, afix felt to end in question and assemble the machine again.
Jun 14, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
What is a glider? My dryer has started making some loud noises and the cloth like material that goes around it in the inside has ripped into shreds. Is this what is causing the loud noises? How and where...
The gliders are a piece of hard plastic that set on the frame, the peice that holds the drum, their is 4 of them and they are on top of the frame, the felt liner is what supports the bottom of the drum on the fram.
Oct 02, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Drum doesn't turn in maytag neptune MDE9700AYW
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Jan 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
We have the same machine. The drum also broke so we had it professionally installed. It wasn't done well enough and after the 90 day repair warranty, other problems developed. We still don't have a dryer and the next repair is $500 as other parts were damaged and we didn't catch it within the 90 days.
Bottom line: do have it professionally installed but be sure to ask about their work guarantee. As soon as you have any problem at all, call them back.
Jul 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
608 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
