Question about Sewing Machines
Please please help me someone, the presser foot of my sewing mashine pfaff 2056 is stopped working. Where can be a problem?
The presser foot doesn't work
  • Sewing Machines Master
  • 1,564 Answers
Your cam lever is probably broke. I'm not exactly familiar with your machine but see if you can get into that area to verify. If that is too much of a challenge. Take it in for repair
Posted on Nov 12, 2012
  • Marina Nov 28, 2012
    Thanks a lot,Sylvia,for your advise.I gave it for repair.I think you was right about cam lever.
3 Suggested Answers
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
RichSew
  • 194 Answers
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Posted on May 27, 2010
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
Walking foot for Pfaff 2030
Not sure what your question is, but the following may be helpful:
Pfaff Tiptronic Sewing Machine with Walking Foot
There are multiple web sites and videos online that explain how to install and use a walking foot.
You can most likely find a walking foot for your machine by searching the internet for:
Make Model walking foot
or contact Sears, a sewing repair shop, or online sewing machine accessory vendor.
What is Walking Foot Sewing Tips for Beginners
How to Use Walking Foot Attachment Sewing Machine
http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx
Pfaff Sewing Feet SewingMachinesPlus com
Nov 27, 2016 | PfaFF Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
The presser foot lever keeps falling down when set in the up position on my Pfaff Performance 2056. How do I fix it?
The presser foot return spring needs to be replaced, it's a inexpensive repair.
This sounds like a job for a repair shop.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 28, 2014 | PfaFF Sewing Machines
How do I replace the power cord on the presser foot to a pfaff sewing machine model 2144?
I highly recommend taking it to a sewing machine repairer. That way you get it repaired safely and have a warranty on the work
Sep 18, 2014 | PfaFF Sewing Machines
Pfaff 2056
What do you call the presser fot...it is actually the pressure on the fabric
Feb 18, 2014 | Sewing Machines
2056 the understitch is loose. Is this a problem wit the tension ?
Sounds like a threading problem. Thread the machine all the way to the needle but not the needle eye. Then pull on the thread and lift the presser foot up and down. You should have tension when it is down and no tension when it is up. If this is the case try sewing, should fix the problem. If this is not the case your machine will need to be adjusted buy your pfaff dealer.
Hope this helps
Mar 22, 2011 | PfaFF Hobby 4260
Pressure foot problem
hi there not sure if the manual will help but if you go to this link you might find it.
pfaff 7570 manual Google Search
or go to this link might help you to find out why.
pfaff 7570 presser foot wont go down Google Search
Nov 04, 2017 | PfaFF Creative 7570
Sewing Machines Logo
63 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
