Question about Casio Parts Cash Register PC Desktop
Spare cash Note Clip
3 x Casio -A 102 Note clips required For existing Till.
  • Casio Master
  • 1,646 Answers
Contact a Casio dealer and tell them you need bill holders for your drawer. They are not too expensive.
Posted on Oct 29, 2012
  • 397 Answers
SOURCE: casio cash register te-m80
Remove the wall plug and the batteries at the same time, wait ten minutes, put the batteries back first and then plug it back in and turn the key to Reg, you should see a row of zeros across the display as the machine resets itself.
If this doesn't happen the machine is dead and that is very unusual for a Casio.
Posted on Aug 21, 2008
flexion1
  • 737 Answers
SOURCE: cash register showing E94
Hi. It has a printer fault. Make sure there is nothing stuck in it. If the printer spins at turn on then it is probably an electrical problem and you need to take it to a dealer.
Posted on May 04, 2009
flexion1
  • 737 Answers
SOURCE: Casio Till frozen
Hi. Turn power off on bottom of machine. Hold down the top right button on the keyboard. It doesn't matter which product is programmed there, it must be the top right button. Turn on at bottom. When you see the copyright message, let go of button and press the right part of the subtotal button. when it asks to flag clear, press Yes
Posted on Dec 27, 2009
flexion1
  • 737 Answers
SOURCE: a till won't open the cash draw tried different
It usually means the drawer wiring has been shorted out at some stage and the internal fuse (most models have a drawer fuse on the main board) has blown. Occasionally the drive transistor may have blown open also. If you want to have a go at it yourself and save some money, C-tech has a service manual here:
http://the-checkout-tech.com/estore/catalog/product_info.php?products_id=334
Once you have it, I can direct you to the relevant parts/ diagrams etc for drawer drive.
Posted on Feb 07, 2010
Testimonial: "seems a rational explanation of the fault, it would account for why it abruptly ceased performing. cheers!"
Electroboy
  • 1646 Answers
SOURCE: cash button only registers 2p
Try this:
Turn key to program 0 CASH SUBTOTAL Turn key back to REG and try it. -------------------------------------------------------------------------
If anyone needs more information, the Casio TK-1300 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
Posted on Jun 06, 2011
Broken money clip
Hi Bob. They are called Bill Holders and you can buy them from a cash register dealer
Feb 26, 2014 | Casio Parts Cash Register PC Desktop
HOW DO YOU REPLACE A BATTERY ON A CASIO 1572 A168
This is how I replaced the battery on my Casio 1572 A168 watch.
1- Undo the 4 screws to remove the back cover. Note the correct orientation for reassembly by observing the writing.
2- Gently pry out the mechanism.
3- Undo the 6 clips round the circumference of the mechanism with a pin or watchmakers screwdriver. The top half should come loose. There is also a 7th clip which can be more easily unclipped from underneath. Replace the battery.
4- Note the correct position of the small spring. This spring is necessary to make the watch speaker work.
5- Note from the picture the correct position of the special contact which connects with the lower board. If this does not connect properly then the display will disappear.
6- With the battery in place, the watch display should work properly. If there is a problem try connecting the two all clear contacts with a screwdriver, paper clip or small piece of wire to reset the watch.
7- Reassemble the watch and make sure the rubber seal is in place. The seal on my watch was slightly deformed so I used a very small amount of silicone sealant on the tip of a screwdriver to tack it down properly.
8- Put on the back cover being careful not to overtighten the 4 screws and damage the threads. The cover needs to be positioned correctly and not 180 degrees in reverse so the spring will connect with the correct place. When you look at the front and back of the watch the writing should be the same way round.
Kind regards
Chris
*Looking at the picture it might also be possible to replace the battery by removing just the one clip that is closer to the spring. However I found that that clip is more easily undone from underneath, so I preferred to do a more complete dismantling. This also gives more freedom to reposition the battery.
Feb 26, 2013 | Casio A168W Wrist Watch
Screen has frozen Casio qt 6600
flag clear the till, and try again,
if it is a long report the till will stop and then start
flag clear power off the till on the side
hold the button down at the front
power on the till
press the ok button
then after 30 sec to 3 min
press yes
Feb 09, 2013 | Casio QT-6600 Cash Register Touchscreen...
How do i reset the casio te-2200-1 cash register till back to its manufacture settings
This is not advisable as you will lose a large amount of settings and data. If you are not familiar with memory allocation procedure, key allocation procedure, machine features settings and function settings, then it would pay to avoid a full RAM clear. It would be much easier to edit the existing programming to suit your business.
If you still want to RAM clear the machine and start again, you will need the tables from the Casio TE-2200 dealer manual:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
To program the basics such as Item names/ prices and receipt message, the user manual is what you need:http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_users_manual.html
Sep 30, 2011 | Casio Parts Cash Register PC Desktop
Cash button only registers 2p when pressed to open till. till is casio tk 1300 dont know how to re program it to just open.
Try this:
Jun 06, 2011 | Casio Parts Cash Register PC Desktop
Casio tk-2700 little plastic clip that holds the paper in place for printing are broke
If you mean the small clear plastic guides, they are hard to get now. you don't need to worry about the one on the journal side, but the receipt one can cause the paper to jam when issuing receipts. You may have to contact some dealers in your area to see if you can obtain one. This printer was also used in other brands such as the Sharp ER-A570 so try Sharp dealers too.
If anyone needs a manual for a Casio TK-2700 cash register,
Operating: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-2300_and_TK-2700_users_manual.html
Programming: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-2300_and_TK-2700_and_CE-4700_programming_manual.html
Sep 25, 2010 | Casio Parts Cash Register PC Desktop
How to change tax rate on casio 3700
KEY REQUIRED: PGM KEY
TURN KEY TO PROGRAM MODE:
ENTER 3 PRESS [SUBTOTAL]
ENTER 0125 PRESS [SUBTOTAL]
ENTER 070000 PRESS [CASH]
ENTER 0 PRESS [CASH]
ENTER 5002 PRESS [CASH]
PRESS [CASH]
PRESS [SUBTOTAL]
TURN TO REG POSITION
The BOLD Underlined entry indicates the tax line...this example is for 7%
Apr 02, 2009 | Casio Parts Cash Register PC Desktop
Casio TK-2100, Change the departments.
Hi.
All the settings require different codes. What did you want to change, price, tax status etc?
Mark
Feb 03, 2009 | Casio Parts Cash Register PC Desktop
Casio tk-7000 scanning and PLU programming
You can add a Hand held Scannerbar with your Casio Tk -7000
Hand held bar code scanner(HHS-15) *
Essential functions for the scanning environment such as Not Found PLU(NFP),PLU batch maintenance file,bottle link and Mix & Match functions are available on the TK-7000 model.
You can attach a Voyager Scanner with your TK-7000 model.
How to add in Casio Cash Register:
1. connection to cash register - unscrew and screw back in.
2. connection to scanner, unplug using paper clip into hole and push back in again.
3. rescan default sheet given whe nyou purchased the machine.
4. clean head of scanner.
5. check for cracks on scanner, ie. loss of vacuum.
For MOre Information visit the following sites:
1. Multisoft India
2. Cash Register
3. Bar Code Basic
4. Scanner Model
5. Casio 7000
Regards
Ellin
Oct 07, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
32 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
