Question about GE Profile Performance 29.8 cu. ft. Side-by-Side Refrigerator with Dispenser TFX30PPBWW
I have a GE profile model # TFX30PR the plastic tube for the icemaker keeps freezing
How hard is it to change the water valve in the icemaker ?
    Top Expert:
  • GE Master
  • 9,472 Answers
The water inlet valve is bad allowing the water to drip into the tube and allowing it to freeze there clogging the tube. This is the most common cause for the tube to freeze. You will need to replace the "water inlet valve" on the back of your unit. Here is the part you need to order.
Posted on Oct 29, 2012
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
ginko
  • 19396 Answers
SOURCE: Icemaker not working, freezer not getting cold enough....
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
mreid542
  • 166 Answers
SOURCE: GE Profile Icemaker freezing up; water freezes
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Posted on Jul 01, 2010
I get drinkingwater but the ice maker just wont make ice any more is something plugged where the water comes into that part that makes ice .Nothing looks broken only wont make ice?
SOMETIMES THE ICE FILL TUBE FREEZES UP, TO CHECK THIS REMOVE YOUR ICEMAKER AND LOOK UP IN THE FILL TUBE , IF IT IS THAW OUT, IF IT IS NOT IT MIGHT BE YOUR WATER VALVE,( YOUR WATER IN THE DOOR WILL STILL WORK) OR IT MIGHT BE THE ICEMAKER ITSELF
Jan 19, 2011 | GE Profile¿ 26.5 Cu. Ft. Stainless...
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker freezes up
Good day,
Common problem on all refrigerators.
It is usually caused by a bad water valve located on the rear bottom of the machine.
What happens, is it fills the ice maker, and is supposed to shut off completely.
If it dribbles instead of shutting off completely the water will start to freeze in the tube, and eventually freeze the tube shut.
Dec 12, 2009 | Refrigerators
I have a GE Profile side by side fridge and need help with my icemaker. It's making great ice but seems to have to much water. Is there some way to adjust the time on for the water fill valve?
Your model has the electronic control behind the front cover and not very serviceable. The part number providing your refrigerator is the PSW26P model the ice maker part number would be WR30X10093 for that Model. You may also take into consideration that it is also a possible bad water valve on the rear leaking after shut off. That would show up as water running over the sides and the freezing and possibly freezing the fill tube in the back of the ice maker causing water to go everywhere. But most likely it is the control board inside the front of your ice maker. Thanks Sea Breeze
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker fill tube freezing water dumpng all over floor
either the water solinide valve is faulty and allowing water to escape/ water pressure is to low or air is getting into freezer from the back of fridge freezer were the fill tube inserts
Sep 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
I am unable to get ice. Cleared the tube.....arm on ice maker is down. I have a ge performance profile TFX22PP
Pour about 1/2 cup of water into the icemaker . If it dumps the cubes after freezing , replace the water inlet valve . If it holds the frozen cubes and does not dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc ...
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker water line freezes
it is probably a faulty water valve that slowly leaks water up to the icemaker and freezing. sometimes it will freeze inside the fill tube and block the water supply completely.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
THE LINE THAT FILLS THE ICE MAKER KEEPS FREEZING WHERE IT COMES INTO THE BACK OF THE FREEZER WHAT CAN I DO
change the water valve on the back of the machine. the valve is very slowly leaking water up to the icemaker and freezing in the tube eventually blocking all water from going to the icemaker.
Aug 01, 2008 | GE Refrigerators
Ice maker tube freezing up
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
230 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
