Question about Velodyne VRP-1200 Subwoofer
Woofer,s outer ring is ripped.
Velodyne servo 1200, about 18 years old. works fine. The woofer cone outer ring is ripped. I would like to replace the whole whoofer. where can I buy a new woofer.
Diamter 12 inches. Linear travel: 9/16 peak to peak.
Voice Coil: Copper: 2-3/8 Dieameter. 1.1 Lenght.
Magnet: 56 oz
Cone: Resin impregnated fiber
Accelerometer: Piezo with intrgral amplifier.
Integrated Class A/B 100 watts continuous RMS, 400 Watts peak.
  • 124 Answers
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Posted on Jan 04, 2009
I have velodyne hgs15bg powered sub.. After a prolonged hard run, it developed a rattle at mid to higher volumes. what went wrong ??
You possibly ripped the woofer cone or welded the voice coil - something mechanical. There's only one thing in there that moves on purpose.
Mar 03, 2011 | Velodyne HGS-15 Subwoofer
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
I have a set of cerwin vega AT15's my dog decided to put his paw through the one surround and puntured the paper cone I need total 15" woofer replacements or repair. or I need replacements I can buy and...
Ebay sell Cerwin Vega Surround (rubber bit) replacements. If he has ripped the cone too, appart from replacing his back legs with wheels (joke!), contact Cerwin Vega directly and they will send you out a new "driver". These are easily fitted at home by any one with a screwdriver
Sep 02, 2010 | Audio Players & Recorders
My woofer makes popping noise
Depending on your configuration, it could be a loose/**** cable, or possibly digital clipping. If you're playing music (especially MP3s that weren't professionally transcoded) from your computer or player, try first turning down the volume a little from the computer SOFTWARE (in iTunes or WinAmp or whatever), or your iPod, Zune or whatever. If that solves, it, your MP3s were transcoded too hot, which is bummer because using the volume in software is never as nice as in analog.
If that doesn't solve, it, try checking/replacing your speaker wires.
These are the easy fixes. If they don't work you may have a more serious problem, like dust in the speaker or amp electronics, trouble with your crossover, or God knows.
Good luck. Poppy woofers ****.
Dec 04, 2009 | Velodyne HGS-18 Speaker
Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
I hear some noise coming out from the woofer of CHT-12R
It very well could be the spaker leads hitting the speaker cone.
You could check this by removing the amp section from the back.
Remove the screws at the very edge of the amp panel.
Jul 04, 2009 | Velodyne CHT-12 Subwoofer
Extreme distortion with Velodyne SPL 800II
Woofers are subjected to relatively high degrees of acceleration which can cause a poorly built voice coil or spider (an additional support located at the junction of voice coil and cone) to break away from the cone or the surround at the edges of the cone may have dissolved. Cigarette smoke is death to the common foam-type suround and once it is no longer intact, the cone can slap on the frame edges.
Only the very expensive band/concert-type speakers are worth repairing. Check on eBay for the right size replacement; they atart below $20 US.
High quality speakers actually come with a warranty but then, the Chinese company that built them may not outlast the warranty.
Apr 27, 2009 | Velodyne SPL-800 Subwoofer
No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Feb 25, 2009 | Velodyne CT-100 Speaker
Need woofer for B2030A
Check the watts and size on your old woofer and go to radio shack and get a repacement woofer with the same wattage and size.
Radio shack make great replacement speakers and woofers.
Feb 14, 2009 | Audio Players & Recorders
Velodyne VRP-1200 Subwoofer Logo
567 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Vito Vacirca Jr.
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
