Question about Apple Mac Pro Desktop Computer Workstation (Early 2009) (Z0G100026) Mac Desktop
Spinning rainbow wheel and crunching
The spinning wheel and crunching will last for long periods of time which is annoying. This only happens while on the internet. When it does stop crunching it will start again shortly after it stops. What is going on?
  • satin85718
    satin85718 Oct 30, 2012
    Since my Mac Pro is 6 yrs old I am going to put all that I have on an external hard drive. By the comments of wonderful people whom I don't know and they don't know me but are willing to help me, thank you. I will hire someone to come out an put in a new hard drive. Thank you folks for all your help!
  • satin85718
    satin85718 Nov 15, 2012
    To the folks that gave suggestions to my problem .......... I had a tech install a new hard drive and upped the RAM. Problem is solved. Thank you so very much.
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 30 Answers
Spining colored wheel is an indication of either damaged OSX or bad hard drive. Save your data and reinstall the OSX to check if it is just the Mac OSX problem.
Thanks.
Tech from http://www.computerstar.ca/Macbook_repair_toronto.html
Posted on Apr 16, 2013
    Master:
  • Apple Master
  • 545 Answers
The "beachball" and sounds do typically mean that your drive is failing. Your plan to back up is the right choice.
You should be able to replace the hard drive yourself. Opening the case and replacing the drive is exceedingly simple on the mac pro.
Posted on Nov 13, 2012
  • satin85718
    satin85718 Nov 13, 2012
    Thanks, Michael! I have a new hard drive and bumped up the RAM. Also upgraded from Leopard to Snow Leopard. Looks like no update for my Samsung printer. It was a cheap mono and will replace it. Thanks again!
3 Suggested Answers
Macs R We
  • 481 Answers
SOURCE: imac periodically freezes. No recourse but to shut
This behavior is usually symptomatic of an internal drive that is failing or has failed. The pinwheel appears when the drive is unable to deliver a certain block that the CPU needs to proceed. In our shop, we would boot from a Drive Genius CD and run the Scan test on every block on the internal drive. If blocks show up as bad, the best course is to replace the drive. If no blocks show up as bad, we would run DiskWarrior on the file system to clear up any volume inconsistencies, which can also give rise to this symptom. If neither of these solves the problem, we could back up the user files to an external drive, reformat the internal drive using "erase writing zeroes," reinstall the system from scratch, then replace the user files.
Posted on Nov 28, 2009
  • 739 Answers
SOURCE: At login I get the rainbow wheel; i eventually get
This seems to happening a lot at the moment!
From experience it can be a number of things, the worst being a failing hard-drive These imacs are now at least 6 years old and unfortunately HDs don't last forever anymore.
Try starting up from your install Cd and run the disk first-aid found in the utilities menu. Does it fix anything? does the Mac now start up properly. Also while you are in the utility, look to see how much free space is left on the HD. You should have at least 10% of the HD's total capacity free. if not then the system has to work overtime and that invariably invokes the beach-ball.
If the utilities found nothing wrong and you do have plenty of free space then the next thing is to do an "Archive & Install"
This will reinstall the system software which may have become corrupted. The down side is that you will have to run all the updates that you already had done all over again.
You have got everything backed up haven't you?
Posted on May 04, 2010
REAR passenger tire makes loud clunking and grinding noises when turning more than 30-45 degrees above 5-15 mph
I don`t think you have cv axles in the rear of that.My guess would be wheel bearings could be grinding. Donut spares are strickly to be used for short periods of time and not to be driven at any higher rates of speed. Some damage may have occurred during the actual incident when you had the flat initially.Damage to the rear axle itself,
Oct 12, 2012 | 1996 Dodge Caravan
Disc brake noise during cold weather
unfortunately if the truck is equipped with ceramic pads.... well there is the draw back, its a trade off.. like a semi truck, most of them are noisey coming to a stop. lots of weight with a lot of friction causes a vibration thats annoying.SO 1) You could opt for softer material in the brake pads, which would directly relate to a more frequent pad change, but the noise will be gone, and 2) you could try to drive a little ways at about 35 mph and just REST your foot on the brake pad for approximately 1/4 mile then come GENTLY to a stop. procedeure called burnishing.2 times should be plenty, and give the brakes a chance to cool beore the second burnish,( about 3 to 4 mins of cool time) let me know what happens, and good luck!
Dec 13, 2011 | 1995 Toyota T100 Xtracab
2005 250gv making alot of crunching/grinding noise from rear wheel?any sugestions
bearings going raise the rear wheel and spin it see if you can hear a wooshing noise and wheel movement get back to me
Sep 22, 2009 | 2003 Hyosung GV 250 Aquila
The front end feels like it wants to wash out
hi mate this is either a unbalanced wheel/tyre or the bearings rough lift front end up and spin wheel if you hear a horrible wooshing or crunching noise its bearing problems also if there is movement
Aug 29, 2009 | 2003 Yamaha FZS 600 Fazer
Buzzing sound in Acer Aspire 5535
I've come across this before and it turned out to be the soundcard driver. See if there's an updated driver on Acer's website.
Strange buzzing can also be caused by a stuck or damaged key. Does pressing ESC help at all?
Unlikely to be the hard drive. They crunch and grind but don't buzz, unless they're completely knackered, when they can give you a three-tone buzz sound and won't spin up at all.
Hope that helps,
Matt
Aug 24, 2009 | Acer Aspire 5535-5050 Notebook
Older Rainbow Noisey
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=576894
Older Rainbow Noisy
Posted by Capt_Troll on May 06, 2008
I Have an Older Rainbow (i think it's a d4)
my Old roommate ran it once without water.
it Still works now (with water), but
it's Very noisy on start up
Also I Can't seem to remove the separator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? And if so how? Or is this thing on its last legs? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow D4 is an older Rainbow Vacuum and the part where the separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. Other wise the Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit as well. Watch out… the repair of the Rainbow D4 may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Sony KP-57WS510 rainbows and arches
no the shape doesnt matter as long as the STK numbers are the same. I would make sure that the replacements are origional sanyo ICs as often the cheaper versions do not last very long.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Crunching and grinding
That noise come from the pump that drived the water out the drum. Since you don't have this noise every time, it's seems like it's cause an unclean filter issue. Cleaning the filter - should solve this issue. Before openning the filter, prepare a bowl and a floor cloth to avoid water's flooding. Good luck !
May 24, 2006 | Hotpoint First Edition FEW12 Front Load...
Apple Mac Pro Desktop Computer Workstation (Early 2009) (Z0G100026) Mac Desktop Logo
189 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
