Acoustic solutions ds 1233 surround turns off.
I have a DS 1233 surround sound system that works fine when it starts up but after several minutes the system reverts to stereo only. Changing volume up or down by on notch gets the surrond back on.
This happens on all inputs. Any advice most welcome as it would be a waste to have to change system.
  • Anonymous Apr 13, 2009
    Hi I have the same problem with mine did you find a solution to the problem?
SOURCE: Panasonic SC-HT900-problems with surround sound mode and digital input
I tried to fix the popping defect to no avail. I thought if i powered the internal subwoofer fan to a different power source that it would solve the issue. Although the fan spins faster connected to an external power source, and it keeps the sub motherboard cooler, it still pops (less often) and loses sound. The fan just cools it faster so that it can happen again. The working fan only extends the functionality twice as long but still has the same issue. I did notice on the subwoofer motherboard that there's a dark spot near a few transistors/regulators. I suspect at least one of them have already failed causing the system to overheat anyway. I also suspect that if I keep using the system, those will also fail. I will never buy anything Panasonic and neither will anyone I know (I'll tell them all not to). Don't buy this product.
Posted on Mar 14, 2007
  • 979 Answers
SOURCE: ** sound
Hide the remote from the set for awhile and see if some sanity returns. If that's the case, service or replace the remote. (Check the batteries first...accordianman
Posted on Mar 10, 2008
SOURCE: TECHNICS SC-CH550 STEREO SYSTEM
Hi
I belive that you have a lot of dust how is gatherd behind the system in the amplifier and it is preventing it to cool down you need to blow it clean and make sure that you keep the system gets cool air
if the temp in the amplifier gets to high it shut down the system instand of burning it very clever solution from the manufacturer
you have a very good system good luck
Posted on Mar 15, 2009
MBTV
SOURCE: audacity input levels change with every new song
From what I hear, you should try a new sterio system. Plus, you could se if the wires are all plugged in maybe that could be the problem. If you need any more help, Message me at montanaandboostshow@yahoo.com. Hope this Helped!
Posted on Apr 21, 2009
SOURCE: hook up Sony Bravia Home Theater DAV-HDX277WC
Hi....I haven't hooked mine to the TV yet.....building my cabinet now....but I did hook up the components to make sure they worked and just didnt include a TV on it. My S-Air wireless linked up the first time I tried it....I will say this though, the little wireless transceivers blocks you have to plug into the DVD player and the S-Air do not go in like you would think. They actually look like they are upside down when you get them in, and the must snap in very securely. Make sure they dont just LOOK like they are plugged in. Also, dont get em to far away through too many walls, Try linking it sitting right close to the DVD. Also remember the S-Air remote has its own volume control as well as other controls....
I know I wasnt much help but I just got mine and I will be back with more after I try the surround sound on the TV.
Posted on May 03, 2009
System turns off when playing the gameboy sp games after about a minute or two it just shuts off like you turned the power off .It works fine when I play ds games but no matter what when you play a sp game...
I would open the DS and make sure all the wires are hooked up correctly in the bottom slot if they are then call Nintendo and ask if they could repair it.
May 09, 2010 | Nintendo DS Lite
Games not regestering
could be a problem with slot 1, have a look for any broken or bent pins. If everything looks fine open up the ds and push down in the bottem 2 corners and the middle with a screw driver or twizzers to make a slight dent, it just makes the cartridge a bit tighter and moves it closer into the pins. If that dosent work the slot will have to be changed out, which can be tricky, theres 4 legs for the surround and 17 legs at the bottem. good luck
Jan 16, 2010 | Nintendo DS Lite Console
Doesn't have the directions to touch to begin
It sounds like a system crash. If you take the battery out and reinstall it a few minutes later this will reset the system and should solve the problem.
Aug 29, 2009 | Nintendo DS Lite Console
Both Screens go White after i hit start
There is another solution for the guy that had 2 white screens before anything comes up. I have heard this many times. before turing on ur ds, hold A and B. Then turn the power on still holding A and B. Then right when you see the DS screen, hold start and select. So now holding A,B,Start,and Select, the white screens will come up. hold these buttons until the lincenced by nintendo comes up. That means it worked. Depending on how many codes you have, it will take up to 1-5 minutes of holding those buttons. If this doesnt work, dont blame me, I heard it from someone else. I tried it and it didnt work, but thats because there was something else wrong with my AR.
Mar 20, 2009 | Datel Action Replay for Nintendo DS
Nintendo DS start up menu disappeared.
take out all of the games in the ds then the menu should come up then click the little ds picture at the bottom. that will take you to another menu. click on the wrench in the pink box, then click the top box which has an arrow pointing into a box. click the top box which says manual mode then press confirm. the ds will go off then when you turn it on it should go to the menu even with a game in. hope this helps! =)
Dec 08, 2008 | Nintendo Pokemon Diamond for DS
A/s ds1233 manual
i have a written copy that came with my ds 1233 so i could scan it and convert the images to a pdf file that i could email to you.
Sep 13, 2008 | Acoustic Solutions AV 150B Main / Stereo...
I cant rig up my surround sound to my tv
Run a phono cable from the tv output to a input on your system,select this input and you should have sound,if not go to tv menu for sound set up as some tv,s need the output turned up or even to be switched on.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Audio Players & Recorders
Nintendo ds problem
Most likely if you have a touch screen cover, it is not on tight enough, or has been somehow damaged, probably by a tap with way too much force. If this solution doesn't work, message and me and I will see what I can do.
Dec 03, 2007 | Nintendo DS Lite Console
Sorry, my last desc should be ignored here are all to solutions to problems. I know:
Prob: Two white Screens:
Solution: none so far, have emails sent to Datel. see what happens. This occurs when attempting save codes with the DS and the AR is pulled out or DS powered off. My suggestion if you get a new one, only update codes using the PC software.
Prob: AR keeps asking for game cart. insertion:
Solution: remove AR and put in game cart.
Prob: AR not enough memory to update codes:
Solution: there is more bugs in their software/firmware that doesn't really know when items are deleted and space is free. You must reset AR cart. and then use the PC software to reload all the codes:
a) First I would update the AR PC software (no DS AR connected)
b) Connect DS with AR to PC then update the AR firmware
c) Disconnect DS AR from PC
d) DS off hold A+B when TURN ON DS when DS logo shows press START+SELECT with A+B still down as well, hold for a while. turn off DS
e) Reconnect to PC, turn on DS and drag the PC US codes to the DS side. (Note: I had to do 4 & 5 a couple of times it finally worked)
Prob: AR PC software not seeing the DS AR connection: Solution: The PC drivers are not being found for the NDS link. You need to do the following:
a) close the AR PC software, and disconnect the AR DS.
b) connect the AR DS and then the windows new hardware driver install window pops up. must select using the manual browse option.
c) go the the action replay directory either on the action replay CD you bought or from a extracted version from the web. (NOTE: this is not the installed location, but before where the setup.exe exists) I had lost my CD and did about 10 minutes and found a .rar of the source code.
d) pick the action replay subdirectory and click on install
e) you should see the NDS link drivers being installed.
f) start the AR PC software and attempt to connect the DS AR it should work.
-- I hope this helps anyone --
Nov 23, 2007 | Nintendo DS Lite Console
280 people viewed this question
 Grubhead
Grubhead
