Question about Saeco Magic De Luxe Espresso Machine
Flashing green light wont stop on my saeco odea go, wont brew
  • 3 Answers
SOURCE: saeco odea steamer is leaking
This is a known issue with the Odea GO. You need to take it in for servicing to get the rubber seals changed. This happened with our maching after about 6 months.
Posted on Mar 09, 2009
EsWorld
  • 1618 Answers
SOURCE: My Saeco Odea has the red ! light quickly
Open the steam valve and make sure the selector is set to hot water.
Posted on Jun 30, 2009
  • 81 Answers
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Posted on Jan 21, 2010
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
SOURCE: Saeco Odea: The brew group
I had the same problem. I got around it by inserting just the grounds container (which sits inside the dregs drawer) and powering the machine on. Then the machine reset itself to the home position. It wouldn't do this with the dregs drawer removed, but putting in just the grounds container fooled it into thinking the dregs drawer was inserted. Hope this helps. JRP
Posted on Jan 17, 2011
Saeco odea giro flashing light
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not
inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed,
the service door is open.
•on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Odea Go
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
! light flashing... machine won't brew coffee - when i press the button to make espresso nothing happens.. I've tried all the troubleshooting options - nothing works.
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
It is a new Saeco Odea Go machine. Every time I turn it on the indicator lights flash up and down successively and a half inch of water comes out of the coffee spout. The light is then in the ready...
What will the machine do when you turn it on? The green light will start flashing for warming up phase. When it reaches the working temperature, all the lights start flashing in anticlockwise direction and the brew group moves up and start pumping water to rinse the system.Of course half an inch of water will come out from the spout. That is normal.
Sep 10, 2010 | Saeco Odea Go
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
Same problem here. I've googled and see that there are many people with the same problem but no clues about how to solve it:
My Saeco Odea Giro is flashing two lights alternatelly (Dregdrawer Light and Descaling Light). What's the problem and how can I solve it?
Aug 10, 2010 | Saeco Odea Giro Espresso Maker -...
Red ! flashes constantly
The lube is for the o-rings on the brew unit, and the ones on the white plastic valve behind the brew unit. As for the light there might be something a little coffee grounds keeping the door open.
Sep 14, 2009 | Saeco Odea Giro Plus Coffee Maker
Flashing lights
The brew unit needs to be removed and cleaned it is blocked.
Aug 05, 2009 | Saeco Odea Go
Saeco Odea Giro - alarm light continually slow flashing
I had the same problem. I filled everything up and closed it then took the hopper top and placed a small magnet that fit the circumference of the hopper sensor (I took one off of a refrigerator magnet and it fit down into the sensor) and it immediately went green. Hope it works for you.
May 02, 2009 | Saeco Odea Giro Plus Coffee Maker
Odea go
Make sure all part is on place, take out the watertank and put it back again, make sure the brewing unit is fit in place.
After all part is on place, put a container under the steampipe and open the steam knob to make a cup of water, when the water comes in a steady flow, then you can close the steam knob again.
Hope this will help you.
Best regards
/Mirran
Oct 21, 2008 | Saeco Odea Go
Saeco Magic De Luxe Espresso Machine Logo
29 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
