Question about Audi Vehicle Parts & Accessories
2000 audi a6 4.2 oil leaking front engine - Audi Vehicle Parts & Accessories
    Master:
  • 444 Answers
Probaly the front engine seal is shot.
Posted on Oct 28, 2012
Clear oil leakage under front of car
if it's near the ac condenser, in front of the radiator, it may be for the ac oil compressor that's leaking out
if it isn't clear, brown or reddish, it's either engine oil or transmission oil or even power steering
Mar 23, 2015 | 2004 Audi A4
Hi, My audi tt 2000 is leaking oil above the oil filter. It is at the top of the silver box like part that the oil filter screws into. It looks like a seal has broke or a gasket has broke. Any help...
The oil filter has a rubber gasket attached to the end that comes in contact with the filter housing on the engine. If the filter was screwed on with a dry gasket, or overtightened, the gasket could be damaged and leaking. It could be the filter is not tightened enough.
Jan 24, 2011 | 2001 Audi TT
What kind of oil do a 2000 Audi 2.8 Quattro A6 use?
The engine oil specification for 2000 Audi 2.8 V6 Quattro is:
- Cold climate: 5W/30 or 5W/40 semi-synthetic
- Moderate climate: 10W/30 or 10W/40 semi-synthetic
- Hot climate: 10W/40 semi-synthetic
Long life service = MY 2000 ---->
Engine oil grade: 0W/30 synthetic oil to VW specification 503.00/W12 and turbo engines above 154 kW / 200 PS = 503.01
Oct 17, 2010 | Audi Quattro Cars & Trucks
Oil pressure on my audi a4 is low after been service what will cause this
First check the Dip Stick and see where your oil levels are, if its low, then add more Oil as mechanic may not have replaced the correct amount after service. second, if you can reach your Oil filter in the engine just give it a tighten with your hand as it should only be hand tight. and thirdly look for any signs of an oil leak, either Oil spill inside the engine or under the car. Generally Oil levels should be full after any car service. Good Luck.
Sep 09, 2010 | 2000 Audi A4
How much to fix a coolant and oil leak on a 2000 audi a6?
Normally they fix these, during Timing belt Replacement. For an Audi A6 3.0, the replacement interval guide is every 80000miles or 8 years. Repair time, remove and install is 5hours.
The cost of replacing a belt as part of a routine service could be as little as 5 to 10% of the repair cost following a belt failure.
So if you decide to keep your car, keep in mind to spend at least $1000 for maintenance. Mine was a 2000 Audi A6 T2.7. With two, turbochargers under both sides of the engine. I sold it with 80000miles, without changing the belt. Hope this may help.
Sep 08, 2010 | 2000 Audi A6
I want to drain the oil on my 2000 audi a6 avant wagon...where is the drain?
underneath the car in the engine area up in front just back past the front bumper you will find an aluminum cross hatched (criss cross lines) oil pan at the lowest point is the drain plug.
Jan 13, 2010 | 2000 Audi A6
Nissan Altima 2000 - Engine oil leaking problem.
replace the front oil seal. first i would clean the engine with purple power (degrease etc.) then look at the engine and make sure the leak is not coming from above like possibly the valve cover gasket or from the oil sending unit. try to tighten the bolts on the valve cover and even the oil pan. you never know, you may get lucky. i don't know where you are but front seals are cheap but the labor on the job is what costs you.
Jun 16, 2009 | 2000 Nissan Altima
1999 Audi A6-Oil Leak-Front of Engine
could be a bad seal on one of the camshafts. could also be from the valve cover. You need to wash the engine down carefully -don't get the wires wet and look closely for the oil path. is it engine oil or transmission fluid?
Jan 27, 2009 | 1999 Audi A6
Audi engine oil leak?
Sounds like a leaking valve cover gasket. The parts are around $50 to do both cylinder heads from www.ecstuning.com. It's not a major issue, but it may be a sore point to a potential buyer.
Oct 01, 2008 | 2000 Audi A6
2000 Engine oil leak
most likely front cover o-ring. there is a small $4 dollar o ring behind the front engine cover, that leaks. Pretty common problem on your car.
Jul 22, 2008 | 2000 Nissan Altima
Vehicle Parts & Accessories Logo
76 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Phil Fisher
Level 1 Expert
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
