Question about Food Processors
James martin zx545-1 food processor wont work
It wont go on the belt seems ok but I have not looked inside because I cant get the screws out it seems to need a certain type of screwdriver.
SOURCE: Replace Rubber 0 Ring for GE Food Processor Inside Diameter 2 6/8
I decided to trash my 19 year old GE Food Processor that needs a new gasget and puchase another.
Thanks for your interest.
Samella 124
Posted on Apr 10, 2009
SOURCE: Hamilton Beach Food Processor Type FP03 Model 702R Series
I just ordered a drive belt from https://www.goodmans.net/ for Hamilton Beach/Proctor Silex Food Processor Type: FP03 Model: 702R for $7.99 + shipping.
Posted on Jun 21, 2009
  • 145 Answers
SOURCE: Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Posted on Jul 07, 2009
  • 18 Answers
SOURCE: Need users manual for Hamilton Beach food processor Model 718
contact hamilton beach and ask for a manual they will sent it to you. you will need model number
Posted on Jul 28, 2009
htechie
  • 146 Answers
SOURCE: Looking for instruction manual for Moulinex food
Enjoy...
http://kitchen.manualsonline.com/manuals/mfg/moulinex/food_processor.html
I hope this is what you were looking for. Please Rate and give feedback if you liked the info provided. It will be much appreciated. :-)
Posted on Aug 26, 2009
User manual for jamesmartyn food processor
Actually the James Martin processors are distributed by Wahl. You might try contacting them here to see if they can help you find your manual.
http://www.wahlglobal.com/united-kingdom/contact.html
Sep 05, 2014 | Food Processors
The handle had food particals under it
You may have to direct those enquiries at a Kitchen Aid service agent in your country. Here in Australia/New Zealand the bowl parts care not screwed together so it may be a bowl specific to your country.
Mar 25, 2014 | KitchenAid KFP750 Food Processor
Need to remove the proprietary screws from a Braun CombiMax 700
These are called Torx security bolts. You should be able to find the right size at your hardware store.
Jan 08, 2014 | Braun K 750 CombiMax Food Processor
The blender jug from the ZX717X-1 food processor has seized up
hi, where can i get the manual for this food processor?.
Thanks
Feb 27, 2013 | Food Processors
Moter is working but dooh hook not working
hi if you still have problems email me and i will try and talk you through,
it may be the belt (teeth worn out) or the pulley (same problem).
the info given in your post is very vague.
if its the teeth on either the belt or pulley there is a simple fix.
remove bottom of base with screwdriver there should be screws under the feet of machine. use a bike valve screwdriver to remove the two remaining screws(depending on make and model)
remove belt, put RUBBER BAND
Jan 24, 2013 | Kenwood MX270 Patissier Food Processor
I wish to replace the drive belt of my Kenwood food processor, how do I get inside it?! I have the replacement belt.
you can do it just use the right screw driver. some unit use cross philips screw other unit use flat screw type. so check it out before doing that.
Feb 04, 2011 | Kenwood FP110 338 Cups Food Processor
Looking fora belt off my braun multipractic plus belt no 190XL037
i am looking for a belt for my food processor as it broke last week
belt number: 190XL037 model of food processor: 4243
can anyone help ?????
Feb 23, 2010 | Braun Food Processors
Sunbeam LC6200 won't turn off. Only runs at full speed unless the bowl lid is disengaged (the safety swtich still works). Have opened it up and the Pulse microswitch seems ok, as does the rotary speed/off...
OK this is the fix for the LC6200 that worked for me. Unscrew top cover (2 screws) then another screw holding internals to external case. Carefully remove safety switch lever (use long nose pliers from the top next to lever to squeeze plastic barb that holds the levers in to the plastic body). Remove all screws on the bottom. Open and undo the drive shaft pully nut clockwise. Pull out shaft and remove belt. Unscrew motor from chassis plate. From the bottom push out the plastic speed control dial with screwdriver. Remove motor and component boards. Check microswitches. Then remove diac DB3 and replace. Remove triac BT137 600v and replace. PS I used a 800v motorola MAC228 instead. Assemble in reverse. Good Luck.
denisprod
Feb 20, 2010 | Sunbeam Food Processors
Sep 06, 2008 | Black & Decker FP1400 Quick N Easy Plus...
Food Processors Logo
54 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
