Question about Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive
3 beeps at startup no video - Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive
  • Seagate Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card.
This black-screen-and-beeping issue is most common with newly-assembled computers.
Check external cables to make sure they're properly connected.
The most important external connections to check are the monitor's signal cable and the keyboard.
If your monitor cable looks damaged or kinked, try replacing it with a spare.
If your keyboard's cable looks frayed, try a spare keyboard.
Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple.
If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one.
If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer.
If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
Check for additional motherboard power connections.
Yours may require multiple cables attached from the power supply.
There is the standard wide plug, which you know is connected properly because your motherboard is beeping.
However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard.
Check the board's manual to make sure it has all the power connections it needs.
Check your internal cables.
Make sure that the CPU fan is plugged into the motherboard header nearby.
Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code.
Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables.
These cables have unique ends on them, similar in shape to a USB plug.
Refer to the case or video card documentation if need be.
If those cables are not attached, your motherboard may refuse to boot the system.
Your video card may be faulty.
If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement.
If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
Hope this helps
Posted on Oct 29, 2012
Gateway wont startup. One beep followed by two short
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
Nov 12, 2013 | Gateway GT5678 Desktop PC
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Lots of beeps on startup of HP Pavilion DV6000 entertainment pc
Beep Codes
Beep signal Additional indicators Meaning
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Jul 07, 2012 | Computers & Internet
I use an acer emachine EL1600 with intel atom processor Windows XP SP3.dec 2009....of late i have started hearing continous beep noise at startup.does this indicate anything.also the screen scrolls up and...
The beeper is usally there for issues with machine on startup. Have never come across a unit that beeps during use. But judging from what you have described there appears to be something wrong with the video circuits of your machine. Try dropping in an external video card to see if it stops.
Aug 31, 2017 | Computers & Internet
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
No video output on Packard Bell 9750
If the computer is booting, you will hear a beep on startup. If it does not beep, then motherboard may be faulty.
Try first unplugging power cord for 20 minutes, tis can fix minor problems.
Try replacing RAM with old one , or removing modules one at the time.
If the computer does the startup beep, then the video adapter may be faulty. Test using an AGP or PCI video card. A basic one will start at about $20 (£15).
Sep 07, 2009 | Computers & Internet
No video from motehr board, no beep on power up?
No video and no beep on power up. Your video card is failure and internal speaker is lost, so You can't hear beep sound. or may be motherboard problem. You insert a external Video Card in PCI slot, if video is ok, so your video chip is damaged.
Thanks
Aug 16, 2009 | Intel D915GEV Motherboard
Computer beeps and won't startup
try to open your cpu, and fix some hardware inside, maybe theres something lose there like video card or your RAM, i encountered also that problem. try to do this.maybe it can help.
Jan 21, 2009 | Computers & Internet
ASUS A8S-X beeps sometimes on startup!
Hi 1 Long, then 3 Short Beeps: Video error The BIOS is unable to access the video system in order to write any error messages to the screen. Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. Remove your video card inspect it for damage and then re insert it. Try rebooting and see if the error remains. If so replace the battery on the mother board and try a different video card. If you have a video card built in then remove 1 srick of the RAM and re boot. Do the same with the other stick. If the error still remains then there is a fault in the Mother Board I hope this helps!
May 11, 2007 | ASUS A8S-X Motherboard
Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive Logo
114 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
