Question about Bosch 36 in. NIT8653UC Electric Cooktop
Bosch cooktop induction 9000308922 - Bosch 36 in. NIT8653UC Electric Cooktop
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 | Cooktops
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
ELECTROLUX ERROR CODE E95
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
Aug 07, 2012 | Electrolux 30" Electric Hybrid...
Unlock ilve induction cooktop
how to unlock ilve induction cooktop
Mar 24, 2012 | General Cooktops
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 14, 2008 | Dacor Millennia ETT304 Electric Cooktop
Bosch 36 in. NIT8653UC Electric Cooktop Logo
78 people viewed this question
Top Bosch Cooktops Experts
paulcarew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
