I have this err and the machine doesn't work - Washing Machines
  • 14,337 Answers
Hey Doron,need the make and model number to trouble shoot.
Posted on Oct 30, 2012
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: Zanussi washing machine err appears and machine
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Posted on Jul 09, 2011
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
WASHER MACHINE NOISE?
What is your model number?
Oct 26, 2012 | Maytag Washing Machines
My camera says Err 30 turn off and on and re-install battery. this doesn't seem to work....any advice?
Remove the battery, press and hold the power button, or turn the power switch to ON position(depends on the option available in your Camera) for more than 30 Seconds and then reinsert the battery to resolve the issue.
Sep 07, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
I have canon IR-2270, it does not work properly, its screen shows this error message: E000003-0000 please let me know what does it mean and how to solve it. thanks.
the E003 is error code related to fixing unit trouble, in this case with temperature that is too low after the copier is out of standy mode.
You can try to reset the error over service mode:
press asterix key (*)
press 2 and 8 and hold for 3 sec
press asterix key
Choose: COPIER-FUNCTION-CLEAR-ERR, turn the copier on and off again.
If this doesn't helps, you need to replace the fixing heater and clear the error.
Aug 02, 2011 | Office Equipment & Supplies
Power went out then back on and mixer reads err and 12 in the timer turned breaker off then back on still reads err
Leave the breaker off for at least one minute then try it. If that doesn't take care of it then you will need to have Hobart come out and check the frequency inverter (drive).
www.hobartservice.com
May 21, 2011 | Hobart HL600 Legacy Stand Mixer
Maytag A511 has worked faithfully for 26 years.
Either the engine or the drum bearing are worn out and the rotor/drum is touching the stator/tub. It's normal wear and since replacement parts are no longer fabricated i think it's time to buy a new one.
Jan 30, 2010 | Washing Machines
Err F05. We load it, then on start, it will seem to be
F05 fault is the pump circuit so it is probably blocked(check all outlet hoses as well)or at worst the pcb
Jul 06, 2009 | Washing Machines
Epson err 1ec
Follow the link below to Epson and e-mail their tech support. You didn't say what OS you are working with and the Epson site doesn'
t list the 895 model only an 890.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=14359&prodoid=176022&cookies=no
Mar 30, 2009 | Epson Stylus Photo 895 InkJet Printer
Kitchenaid mod#KCM511 - error 2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Feb 14, 2009 | KitchenAid KCM511 Coffee Maker
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
