Question about Whirlpool DU840CWD Dishwasher
Whirlpool dishwasher water not pump out all the way
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherwhirlpool dishwasher - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
Posted on Jul 12, 2010
Leaking from bottom of whirlpool dishwasher.
Pump. A defective pump and/or pump seal may be the cause of a dishwasher leak. The function of the pump is to circulate water in the dishwasher and in some models, to drain the water as well.
Jul 26, 2017 | Whirlpool Dishwashers
My Whirlpool dishwasher GU2400XTP fills with water and pumps out properly but does not wash. The pump hums during wash cycle
is there food particles clogging the water intake for the pump or it could be that the motor is seized from bad seals if that is the case then you may want to see if you can get a new pump motor
Feb 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Problem with built in whirlpool dishwasher
check the arm for food debris,then if its clean,then the pump water impeller in the lower area of the pump needs replace along with the pump seals
Jul 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The water used to completely drain out of the whirlpool dishwasher after the last rinse cycle. now water remains in the bottom. Also noticing decreased flow when actually draining into the garbage disposal...
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Whirlpool 24 in. ADG6340iX Built-in...
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2200 dishwasher, the detergent
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
First Choice Appliance
Aug 27, 2009 | Whirlpool GU2200XTSS Built-in Dishwasher
Dishwashers Logo
288 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
