Question about Frigidaire Affinity ATF7000E Front Load Washer
The washer door doesnt lock so i cant use my washer
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You will need to replace the lock assembly. Here is a link to the part you need. Here is a video to show you how to replace the assembly. It really is an easy process.
Posted on Oct 29, 2012
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
Mar 06, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I cant unlock my 2001 325i bmw
Had the same problem. Dealer changed the tumbler in the key lock. Dealer has to do it because of your key. They have to order the part to. Once you open your door with locksmith dont lock it, leave it open an be careful. Cant remember the exact amount paid, 450-500 for this job at the dealer, lock works pretty good, at times doesnt unlock the other doors, but its under 2 year warranty.
Jan 16, 2012 | 2001 BMW 325
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
My washing machine door doesnt lock properly
its most likely your door lock if it is malfunctioning the washer will not work
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
Oct 19, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Cant open rear doors from the inside; cruise control doesnt work
after cking the child lock, try locking and unlocking the manual locks to see if you can hear any movement inside the doors. if all else fails, you have to remove the door panels.. starting from the aft lower corner, (careful not to tear the plastic moisture sheeting, just peel it back), the door panels are normally held in by plastic plugs and screws under the armrest, etc. once inside the door cavity, ck the linkages for wear or any signs of them being disconnected. try all the lock mechanisms again to pinpoint the cause, its good practice to clear all the drain holes at the lower part of the cavity once you're in there.
Jun 02, 2009 | 1996 Audi A4
Washer (laundry)
try pressing options and select for ten seconds if that doesnt work you have a promblem with the door lock switch open then shut your door firmly try it again if that doesent do it try unplugging the unit for 5-8 seconds then retry if that doesnt do it then pull the bottom panel and look on the left side of the washer there will be a envelope with a tech sheet there with instructions on testing the door lock itself
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Door lock
try crc into lock
if no good replace door lock
Nov 16, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
11F ERROR
Door lock sensor broken/need to replace.
Aug 27, 2007 | Kenmore 43142 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
59 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
