Question about Samsung Straight Talk Galaxy Precedent Retractable Aux Auxiliary Audio Cable Car
My meid number does not work - Samsung Straight Talk Galaxy Precedent Retractable Aux Auxiliary Audio Cable Car
What is the meid number for this telephone vu204 limerik thanks
slide the back off...remove the battery.....the number is under the battery
Apr 02, 2015 | Motorola Mobility VU204 Cell Phone
How can I find my meid number the sticker is off I use Samsung m620
To find the Mobile Equipment Identifier (MEID) on your device, following the steps below:
  1. From the Home screen, touch Applications app_icon.gif > Settings > About phone > Status.
  2. The MEID is provided in two formats:
    • Dec: Decimal number
    • Hex: Hexadecimal number
    NOTE: If your number contains a 0, it is the number 0 (zero).
Sep 16, 2014 | Cell Phones
Recovering stolen meid number on a samsung galaxy s 2
Try locating the original box it came in it usually has a card with it with the MEID number on it. Also try contacting the carrier and explaining the situation. They have it on file but it may be hard to get.
Mar 17, 2014 | Samsung Galaxy S II
How do i recover the dec number cause the sticker is off for w385
*#06# may or may not work. The feature was not added to all Motorola phones until after the w385 was in production. You can also find a website that will convert the MEID into a DEC number. The ESN is not a DEC if it has letters. DEC is only numbers and should start with 26. MEID and ESN or HEX have a mix of letters and numbers. There are converter websites if you find the MEID to convert into DEC. Motorola has one too. I'll find it.
Nov 15, 2012 | Motorola Mobility W385 Cellular Phone
Serial Number/ MEID DEC on an lg shine
May be IMEI not MEID the code *#06# is to view IMEI for general.
NB: IMEI means
I = International
M = Mobile
E = Equipment
I = Identification
Thanks for using FixYa!
Oct 16, 2012 | LG Shine CU720 Cellular Phone
How do i find the modem meid 18 digit number on an hp pavilion dv7 1245dx?
I would suggest contacting HP and give them your tag number, that would identify you as the original owner.
Mar 18, 2012 | HP Pavilion dv7-1245dx Notebook
I dropped my samsung in the toilet so i want to actvate an old one i had until i can replace it but i cant find an meid number on the one i need to use. there is no 14 digit number for it
Thanks for visiting FixYa!
The MEID number can usually be found in two places on your phone.
1) Remove the battery. Under it, there should be a small sticker attached to your phone. Your ESN/MEID number should be on it.
2) If you are unable to find it under your battery, put your battery back in your phone and boot it up. Then press the following keys: * # 0 6 # (Star, Pound, Zero, Six, Pound) Your phone should display your ESN/MEID number.
Jun 13, 2011 | Samsung SCH-u340 Cellular Phone
I a trying to register my cell phone and i need to find my serial number on my samsung sch-u450 phone. Each time i get the messsage that i dont have the right one. Witch one is the right one?
On many phones (but not all) on the phone's keypad press the following keys: * # 0 6 # (Star, Pound, Zero, Six, Pound) This will display your ESN or MEID number.
If this doesn't work, turn your phone off and remove the battery. Under the battery will be a white label with either the ESN number or the MEID number. If you see both, use the MEID number.
Apr 02, 2011 | Samsung SCH-U450 Cell Phone
What is the serial number for this model
VX8500 does not have an ESN. The VX8500 has an MEID. The MEID is a 14 digit hexadecimal value with the following format:
The decimal representation is calculated as follows:
a). Separate the 14 digit hexadecimal MEID into two parts:
Part 1 – the first 8 digits representing the manufacturer code (digits RRXXXXXX in
the figure).
Part 2 – the last 6 digits representing the serial number. (digits ZZZZZZ in the figure).
b). Convert the hexadecimal value of each part into the decimal equivalent:
Part 1 – 10 decimal digits zero filled.
Part 2 – 8 decimal digits zero filled.
If the decimal equivalent of each part is less than the number of required digits, right align
and zero fill to create the required length.
c). Concatenate Part 1 and Part 2 to create an 18 digit decimal number.
Example:
Hex MEID = AF 01 23 45 0A BC DE
Part 1, manufacturer code is 0xAF012345 = 2936087365
Part 2, serial number is 0x0ABCDE = 00703710
Therefore, the decimal representation of the MEID is 29360 87365 0070 3710
Sep 10, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I cant find the ESN/DEC/HEX number on my LG Voyager, and i am trying to switch to the voyager from an LG ENV, what do i do about the ESN #?
I had the same problem initially for the longest time, but I finally found the MEID number...I don't believe the Voyager has an ESN; I think it only has a MEID number. I also have the Voyager, and I am trying to switch from the phone I'm currently using to my Voyager (my other one broke.) But the MEID number is on the inside of the phone, where you place the battery/back cover. It should be on the sticker that says "MODEL NO" on top. And right below where it says "MADE IN KOREA," it should read "H/W REV : 1. 0" unless your number is different. Right below that it should read "MEID : ," with the 14 digit number; I hope this helped!
Jun 23, 2009 | LG VOYAGER VX10000 Cellular Phone
Samsung Straight Talk Galaxy Precedent Retractable Aux Auxiliary Audio Cable Car Logo
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
