Question about Cats
My skoda octravia keepsholding back
My skoda octravia keeps holding back on accelration what could the problem be i had the timing checked and cam belt changed
4 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: 1990 geo storm 2x2, no horsepower upon accelration, change fuel
Try a set of plugs and wires,if not this then you may have a plugged converter.
Posted on Dec 14, 2009
SOURCE: holds back when I accelrate.
Might check not only your vacuum lines, but your timing may also be off.
Posted on Dec 31, 2011
alicantecoli
  • 22246 Answers
SOURCE: cam belt re-fitting for skoda 2l diesel
No problem here its the smae as a VW engine ,now iam not sure if this is a common rail type or a injector pump ,All these engines have a 8mm hole in the spoke flange of the camshaft and pump timing wheel ,common rail may not have one though .Look for the TDC mark on the flywheel through a elongated slot then with the cam gear locked in with a old drill bit through the hole into the hole in the head and away you go ,now if this engine doesnt have any holes then look on the cam shaft for a slot on the back and this is horizontal ,A quick check is is too look at the inlet valve on NO1 and it should point up to the left and the exhaust up and to the right then look for the locating hole if fitted or a slot on the back of the cam ,WHATEVER YOU DO CRANK ENGINE SLOWLY WITH A RACHET , to make sure valves clear slightest resistance STOP .Didnt you paint the gears before you took it off? if the belt has broke then sure as **** eggs you will have at least 6 valves bent .Will be the same as a seat as well this car .Haynes amnuals are not worth the money i have found useless thngs
Posted on Mar 17, 2012
Can be fixed an Original Skoda Fabia 2003 radio that gets stuck changing stations?
Anything can be fixed. I would check the front panel switches first.
Jul 12, 2017 | Skoda Cars & Trucks
Hi any 1 help me I put my skoda radio back in an radio code not working serial no ---skzaz9d2238320
dear you can keep radio ON for 4 hours S.W at acc. it depend to how many time you try .
Jan 28, 2015 | Skoda Cars & Trucks
Skoda octavia vrs deisel turns over but won start
Have you checked the firing to ignite the fuel? Aside from timing, the proper heating of a glow plug is important to ignition.
Jan 04, 2015 | Skoda Cars & Trucks
Why does my 1989 pathfinder engine bog down when you push the accelrator pedal?
Computer not advancing the timing. Check the cam position sensor. The throttle body has sensors that can get dirty too.
Oct 01, 2014 | 1989 Nissan Pathfinder
How to replace camshaft sensor skoda fabia
dear remove engine cover , look to engine top cove , two cam.
there is one sensor at the end of cam shaft fix with one bolt ,remove bolt then move a round then pull out ,
Nov 08, 2012 | Skoda Cars & Trucks
Cam belt re-fitting for skoda 2l diesel
Mar 17, 2012 | Skoda Octavia Cars & Trucks
Holds back when I accelrate.
Dec 31, 2011 | 1997 Chevrolet K1500
Front brake pads 2005 Skoda Octavia 1.9td
I have no idea what a skoda octavia is, but I know brakes are brakes. You have 2 bolts holding the pads in a slide, the bolts have threads only at the top, the rest is the slide, pull those bolts, if that doesn't release the slide, take out the 2 bolts holding the caliper on there, pull the slide out the other way. replace the pads, make sure they go back in the way came out. Put the bolts back on, tighten them up, you should be all set. The pad thickness sensor is just a ground, when the wire hits metal, it turns on a light, It should go off when it is not touching anything. You should have squealers on there too, they give an audible screech telling you it is time for some new pads. Hope this helps.
Apr 26, 2010 | 2005 Volkswagen Passat
Cats Logo
98 people viewed this question
Top Cats Experts
Tom Chichester
Ruth summersides
RANDY POWERS
Level 1 Expert
Are you a Cat Expert? Answer questions, earn points and help others
