Question about Utilitech 1/2 HP Cast-Iron Transfer Pump 55832-UTL1
I bought a unitech 1/2 hp transfer utility pump. I would like to remove coming uderground water fron the shallow pit. What happened after the pump remove this water. When the new water come isit start by itself or i have to prime it again.
    Sergeant:
  • 293 Answers
Install a foot valve (check valve) at the end of the suction line so that you don't have to prime it again. Install a level controller so that it will automatically switch on and off according to your predetermined high and low water levels.
Posted on Nov 06, 2012
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
1/2 hp shall well pump. set at 30/50....seems to hesitate around 48 for an extra amount of time....have to shake the hose or tap the pressure plate to get pump to cycle off. also....noticed the pump...
50 PSI for a 1/2 HP pump is approaching the upper limit for that pump. Many things can affect the upper limit. How far the pump has to pull water up the well pipe, is there any air leak what so ever on the input. If the pump lost its prime because it could not attain the 50PSI, I would suspect it may be just outside the limits of the pump at this point in time. If this pump is on a shallow well, it may be that the shallow well point is beginning to plug and not allowing as much water in which would cause a harder pull for the pump. I would turn the high pressure side down to maybe 45 and see if it operates properly at that pressure.
I hope this helps.
Jun 22, 2010 | Flotec Corrosion Resistant Shallow Well...
If i leave it pumping all night and the water dries up will it burn out the motor?
yes besides the water keeping the pump cool it also acts as a lubricant for pump no water can burn up and seize pump
Mar 15, 2010 | Craftsman Professional 1/4 Hp Submersible...
How do you add oil to a sump pump? Do you add it to the water in the pit?
dont add oil to water-- if u have to or want to oil motor get a spray lube unplug unit and at bottom remove debris guard only clips on and spray shaft and behind impeller if need to lube upper motor bearing unscrew housing and carefully pull up enough to lube top of motor replace housing careful of watertight seals and test pump oil poured into pit would only be pumped out and does not contact motor which sits in watertight housing
Jan 25, 2010 | Little Giant Submersible Sump Pump, 1/4 Hp
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
Correct placement for Flotec Utility Pump
should be in drain basin to work properly and check that float moves freely.
May 26, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Pump 30/50lbs pumps up to 50 shuts off pressure drops to 32lbs
Look for a place in the pipe from the pump to the house where an air pocket could form. That will fool the pump.
Mar 29, 2009 | Flotec Corrosion Resistant Shallow Well...
Ive got a shallow jet pump model sd510 it runs all the time and it pumps the water from our holding tank to sump pit it runs about 250-300 gallons through to the sump pit ive replaced the pressure switch...
Just curious, why do yo9ur run water from a tank to a pit?
Where is the pressure switch located? At the pump I presume? What will increase the pressure? If you are pumping to an open pit, you will never build up any pressure? What is supposed to restrict the pump to create pressure?
You need a restriction to create pressure to turn off the pump. Is there a float valve like in your toilet in the pit? If not this would be required
Good Luck
Jan 04, 2009 | Plumbing
Utilitech 1/2 HP Cast-Iron Transfer Pump 55832-UTL1 Logo
343 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
