32RA108S Olevia LCD has no picture
No picture
How do I change the picture size on my Olevia tv
Our 47" Olevia remote uses 'Aspect' to set/change the size and aspect ratio of the picture- look to see if yours is also so marked.
Sep 28, 2014 | Olevia LT42HVi 42 in. LCD Television
I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
Apr 23, 2010 | Olevia Kolin DLT2711M 27 in. LCD...
Sound but no picture
Either your voltage is low or your panel is bad. You have to call a service shop in order to have them dissect the problem
Apr 07, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Olevia intro comes on but then picture goes blank but sound is on
Ur LCD inverter board is dead.Replaced this board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Apr 07, 2010 | Olevia LT42HVi 42 in. LCD Television
I have sound but no picture on an Olevia 237V
If you get no picture on all inputs (TV, DVD, ETC.) then the problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board.
Nov 01, 2009 | Olevia 237T 37 in. LCD TV
My pwoer supply blew up as well part number HGP 180-p240JIFE
Ladies and Gentlemen,
Relative to Olevia TV Power Supply Problems Solution provided by: kb8tez Matt, the problem he had was Electrolytic Capacitor CS21. Upon careful examination of the Power Supply Circuit Board I find that CS21 is in parallel with CS22. Simply replacing BOTH Capacitors makes for a more permanent fix. Radio Shack P/N 272-1032 1000UF 35V Capacitors @ $1.59 each plus tax makes a very inexpensive repair. Apparently the same power supply circuit board is common to many different Olevia Models.
Fastest Robe
Aug 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Picture on Olevia lcd is too large for screen.
If you are on a cable or dish box, check aspect setting from you box, TV needs to be 16-9 or full, set TV first then change setting on box.
Aug 09, 2009 | Olevia LT32HVM 32 in. LCD Television
Olevia tv
try unpluging, wait about 30 seconds and plug back in.
Mar 23, 2009 | Olevia LT32HVE 32 in. LCD Television
Have sound but no picture
power supply or main board ( possibly missing clock signal)
Mar 26, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
