Question about Frigidaire Ovens
Oven ignition problems - Frigidaire Ovens
  • 3 Answers
Sounds like you might have an issue with your heating element. Go to www.RepairClinic.com to find the correct replacement part for your oven/range. I have used them myself to fix my oven and also my dryer, a very helpful site. Good Luck.
Posted on Oct 28, 2012
GE JGBP33 gas oven will not light. Burners and brioler will light. When trying to ignite oven, igniter will not glow, and I see no change in voltage accross igniter contacts. What's next step to...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 27, 2011 | GE Ovens
Oven will not light
If your husband is handy and it is Igniter.. this is a job he can do. remove the burner cover and them the burner baffle and unscrew the igniter cover and pull the igniter out remove the wire nuts and replace with igniter part number WB02X9154 let me know how it works out for you.
Nov 18, 2007 | GE JGRP17 Gas Single Oven
Tip
What the problem is when your gas oven ignitor glows,but no heat for the oven
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
on Jul 31, 2011 | Ovens
Oven "bake" burner wont ignite on a gas oven.
heatman101
Dec 27, 2010 | Whirlpool Ovens
It doesn't ignite the oven. The broiler works. How do I replace the bad igniter?
heatman101
Nov 23, 2010 | Ovens
Emy amana oven will not immediately ignite. we will turn it on and there is a delay before it ignites and prior to that there is a loud popping noise which even rattles the oven door as if there is gas...
heatman101
Sep 30, 2010 | Amana Ovens
Oven flame does not ignite
sure sounds like air flow problem
Aug 11, 2009 | Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
419 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
