Question about GE GSL25JFPBS Side by Side Refrigerator
Freezer working but the refridgerator not cooling and the light is not working
    Top Expert:
  • GE Master
  • 9,472 Answers
If the freezer side is working fine and there is no cooling or lights on the refrigerator side, you will need to replace the control board. Here is the part to order.
Posted on Oct 29, 2012
  • 9 Answers
SOURCE: Freezer is frozen and Refridgerator not cooling
It sounds like you have aproblem with the defrost cycle. Three parts make up defrost system in most refrigerators. The heating element, bimetal and defrost timer, these components need to be checked to determin which is bad. The heating element and bi metal are on the coil behind the freezer back wall, if you have someone who can use a volt ohm meter, with the food removed and refrigerator unplugged ck for resistance on the element if you get a measurment its good, the bimetal will give you a resistance measurment as long as its covered in ice. if these two check ok you may have a bad defrost timer. Id check the bimetal first, hope this helps.
Posted on Mar 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Refridgerator & freezer not cooling much, ice crystals on inside of freezer
Need you to unplug and remove the back panel in freezer to examine the evaporator coil. Check the defrost element and the defrost thermostat. On the back of the refrigerator is a main control board located behind a panel screwed to the refrigerator back. With the power off through all of this I need you to inspect the control board for burn marks on both sides. Click on link below and enter your model or 1 of 34 models like yours. Place model GSH25JFR in model parts search this will lead you to the many similar models like yours. On diagrams on left of your screen count eight down that shows the circuit board. If no burn marks I will tell you how to test the other parts I mentioned,
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: model pds22mbsacc, bought control board
Sorry for your troubles. The fact that you replaced the control may be unfortunate, that`s still to be decided. Was this the symptom (cold freezer, but not cooling in fridge section) you had previously ?
In any event, the important part of all this is the freezer. As long as it is working, relative to how close to correct temperature, i.e. 0 to -10 degrees it is, you`ll never need a control. As long as it is freezing, that in itself indicates you simply have an air-flow problem. You`ll want to check the evaporator fan motor located on the back wall of the freezer (you may be able to see it through the grill like cover). Verify it is rotating or if it is not. You may need to manually hold the freezer door switch in the closed position to make it run (assuming the fridge door is closed on some units).
Once you determine whether or not the fan is running you`ll then either need to replace it, or what else is blocking/obstructing your air flow into and from the fridge section.
Hope that help`s you move forward. Let me know.
Good luck.
macmarkus :)
Posted on Dec 02, 2009
Testimonial: "Very helpful. Thank You"
  • 207 Answers
SOURCE: GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Posted on Feb 24, 2010
SOURCE: Refridgerator and freezer is not cooling. Ice
same happening to my fridge. let me know answer. Mariah26@comcast.net
Posted on Mar 24, 2010
Kenmore side by side refridgerator - freezer works very well, refridgerator not very cold, setting is on coldest set point.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Refridgerator not cooling but freezer works
check to see if freezer has ice on it if so it is going to be the automatic defrost system
May 02, 2009 | Refrigerators
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
83 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
