Question about Maytag Bravos MTW6600T Top Load Washer
I am getting an f 1 reading on my washer - Maytag Bravos MTW6600T Top Load Washer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Call Whirlpool at 800-688-9900.
I think there is a recall on that machine.
Let them know you have a Bravos or Oasis washer and you are getting a F1 error code.
I think they will send someone out to replace the controller board for free on that unit. If not, here is the part you need.
Posted on Oct 29, 2012
I am getting a code F06. What does this indicate?
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
(tip courtesy JSRock)
Thanks for using FixYa$%^^
Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
My front load washer has an error code of F06, but my book doesn't tell me what that is, and the washer won't run
Thanks for using FixYa#$%%^
Jan 04, 2011 | Frigidaire ATF6000ES Front Load Washer
I get f6 code what do i do
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I get a F6 code on my washer after the wash cycle starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
I keep getting an F6 code error.Please advise
Sep 14, 2010 | Kenmore Elite 45986 Front Load Washer
I get the error message of 06 F - for the Kenmore Elite smartwash.
Aug 24, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool front load washer does not start. The
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$#%
Aug 01, 2010 | Whirlpool AWM8143 Front Load Washer
Whirpool Duet Washer
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an F6 code - the washer will not go through its cycle. What do I do? I got this message before and had a technician out to look at the washer and he said there was nothing wrong. I unplug it...
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
(Tip Courtesy JSROCK)
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
KitchenAid front load washer KHWS01PMT2 F06 code. The motor will turn and run with nothing in the washer. With items in the washer, it will try to turn a couple of times then stop and throw the code. I...
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
